Does anyone have a recommendation for the following, my left Turn Signal/DRL (C5) is not working, however when I turn the headlamps on the DRL lights up but the turn signal does not work. When I just turn the car on the LEFT DRL does not work nor does the turn signal. I do get a rapid turn signal from the car and the Left Tail light blinks rapidly. I have read as many threads as possible on this problem before posting and I may have just missed the solution. I have already checked the bulbs, they seem to be just fine, I have tried one persons thread about the hazard lights but that did nothing to resolve the problem. I am wondering if replacing the bulb will work, or if I probably need to check/clean the bulb connection or is the relay switch the issue?
Does anyone have a recommendation for the following, my left Turn Signal/DRL (C5) is not working, however when I turn the headlamps on the DRL lights up but the turn signal does not work. When I just turn the car on the LEFT DRL does not work nor does the turn signal. The DRL will not come on until you release the parking brakeI do get a rapid turn signal from the car and the Left Tail light blinks rapidly. This is the cars way of telling you that a bulb has blown I have read as many threads as possible on this problem before posting and I may have just missed the solution. I have already checked the bulbs, they seem to be just fine, I have tried one persons thread about the hazard lights but that did nothing to resolve the problem. I am wondering if replacing the bulb will work, or if I probably need to check/clean the bulb connection or is the relay switch the issue?
You have dual filament bulbs in the turn signal/DRL housing
It definitely sounds like the bulb is out to me. For whatever reason I've had your exact problem about 4 times within the past six months. Every time but once I got away with replacing just the bulb. Just one time I had to replace the fuse to. Go grab a bulb at wal-mart for 8 bux and let us know how you make out. I'd bet a lot of dough this will fix your problem Good luck!
