After alignment, something pops. Any ideas?
Old May 11, 2009 | 11:21 AM
ALEXAMES's Avatar
ALEXAMES
Default After alignment, something pops. Any ideas?
I am going to call the shop today.
I had my car aligned a few weeks ago. Now, if I'm sitting still and turn the wheels or if I'm rolling slow with wheels turned and hit a bump, something pops in the front end. Any guesses as to what this might be? I had him zero out the toe, basically looking for good tire wear.
Old May 11, 2009 | 11:34 AM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Same happened to me.... Alignment shop did not torque everything down. I found a bolt loose on the lower A Arm. Check to make sure everything is torqued down to spec before you go cruising again...
Toque
Old May 11, 2009 | 11:41 AM
crAzy's Avatar
crAzy
I have a popping noise when i go in reverse from the front i think. Also sometimes from the rear. My car is slammed though. So no front bolts and the rears are 8" long compaired to 6". You think that could be a problem?
Old May 11, 2009 | 12:08 PM
ALEXAMES's Avatar
ALEXAMES
Toque
I'll check this tonight. Thanks Toque.
Old May 11, 2009 | 07:34 PM
Toque's Avatar
Toque
Please tell me you did not go to the GoodYear shop in Wylie....
They screwd up my alignment 2x times on my Z06. They were just using hand held wrenches, and not a torque wrench. Within 1500 miles both times I found that the lower A arm bolts had come loose (yes, turn with my finger)
I went to the Porsche "RUFF" dealer in Plano and they did it right a month ago. They also found my rear suspension loose big time too. Porsche torqued everything to 110ft lbs. They do all the work for 21st Century Musclecars. Quality job I found ! He marked all of the bolts for me keep an eye on to see if anything loosens over time.
I guess it pays to get it right the first time. I know that now if I ever need an alignment.
Toque
Old May 13, 2009 | 05:39 PM
3whit's Avatar
3whit
Default Check Sway Bar Links
It could be coincidental that this is happening after an alignment ,but the popping sound is familiar to me .After I changed my sways I didn't get one link tight enough and I got the pop thing goin on .Very easy to check and you can then eliminate that as the source .Good luck ..
Old May 13, 2009 | 05:46 PM
Toque's Avatar
Toque
Could you describe the pop sound you heard in your situation ? Only happens when turning hard ?
Toque
Old May 13, 2009 | 07:12 PM
3whit's Avatar
3whit
I would hear it when entering my drive way . Slight turn and small dip , and it would do it predictably every time drivers corner was in compression and wheel was turned slightly. I had replaced my sways with Hotchkis and installed adjustable end links ,just didn't get the drivers side link tight . The sound was a very distinct click like if you were to hit two 1/2X 12 inch socket extensions together.
Old May 13, 2009 | 07:36 PM
dobewillie's Avatar
dobewillie
good luck with getting it right
Old May 13, 2009 | 08:06 PM
thehammer69's Avatar
thehammer69
Toque
A 110 ft/lbs still isn't enough...the spec is 125 ft/lbs and it really is what's needed to keep it from moving.
Old May 13, 2009 | 08:58 PM
Toque's Avatar
Toque
Thanks for that. Im going to do some looking in the shop manual. Maybe tighten them myself and let them know about the correct spec !
Thanks !
Toque
Old May 15, 2009 | 03:03 PM
ALEXAMES's Avatar
ALEXAMES
I checked every front end nut and bolt I could get a wrench on, they were all tight. I'm frustrated. Car only has 17K miles.
To After alignment, something pops. Any ideas?
