fuel level sensor replacement
Old May 11, 2009 | 05:37 PM
Muddbug1's Avatar
Muddbug1
St. Jude Donor '08
Default fuel level sensor replacement
I'm sick and tired of this gas gauge issue and trying to find a round about figure on how much its gonna cost to replace one or both if need be. I thought I seen a thread on here that talked about the labor hours and the prices for the parts but I can't find it.
I just talked to the dealership and this was the quote for a 2001 Coupe:
$45-diagnostics
$438-LH tank(this is level sensor only)
$842-RH tank(the entire assembly has to be replaced)
Does this sound about right? I seen in one thread a member paid $900 but he didn't say for which side. I just don't want to get screwed cuz I'm uninformed about something.
Thanks in advance for any assistance.
Wade
Old May 11, 2009 | 06:50 PM
Muddbug1's Avatar
Muddbug1
St. Jude Donor '08
bump
Old May 12, 2009 | 07:19 AM
clif's Avatar
clif
St. Jude Donor '09-'10
This is a rip-off from yoru local stealership! You can order the left side level tranmitter from Gene Culley for around $150. You may not need both. I found someone on this forum to GIVE me the right side level sensor!
Just keep looking here and you will find what you need!
Old May 12, 2009 | 10:44 AM
bucwheat's Avatar
bucwheat
Please try a bottle or two of Seafoam first,I was close to replacing mine and a fellow club member told me about it,great stuff,I used two bottles to fix mine 9 months ago and no problems since. A very cheap fix.
Old May 12, 2009 | 01:23 PM
ronjon3's Avatar
ronjon3
What's the procedure of adding Seafoam??? I know you apply it to the gas tank thru the gas nozzle but do you apply it on a 1/4, 1/2, 3/4 or full tank of gas????
Old May 12, 2009 | 02:17 PM
Cirrus8's Avatar
Cirrus8
Techron, purchased at any auto supply store, will also fix a faulty fuel gauge system. If you have Chevron or Texaco gasoline in your area, they both contain Techron. It may take a bottle or two of Techron to get things to work, but it WILL work.
Old May 12, 2009 | 02:32 PM
poolboy's Avatar
poolboy
with any additive, put it in (check label for how much to put in based on how much gas is in the tank) then fill the tank so it mixes with the gas.
Old May 12, 2009 | 02:38 PM
Drewstein's Avatar
Drewstein
Mine is getting fixed as we speak. I have always run Chevron or Shell in the car but eventually they die. I was on my way back from a long cruise when the gauge went from 1/2 to E but the car still had 8 gallons in it when I filled it. It stayed on E all the way to the shop later in the week.
To the OP, they are ripping you off. You're asking for nothing but trouble by going to the dealer.
Old May 12, 2009 | 02:42 PM
Sinister-one's Avatar
Sinister-one
I wonder if these additive will help the wifes Tahoe..... at about 1/4 tank reading on the gauge the damn thing runs out of gas...... ask me how I know..
Old May 12, 2009 | 02:46 PM
Fastbird's Avatar
Fastbird
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
Replacement part number for the left sender (the one that typically is the issue) is 10333749 and GM Parts Direct is showing a current cost of $77.51. Any of the forum parts vendors (Gene, ect) should be right around there in pricing too.
The fuel pumps are easy to get to. Remove rear left wheel, remove fender inner liner, drain tank, remove pumps straight out the back of the tank if the car is a 97-02.
Old May 12, 2009 | 07:15 PM
NemesisC5's Avatar
NemesisC5
So if just adding Techron can fix the problem.....what caused it in the first place?
Old May 12, 2009 | 10:11 PM
Armycop's Avatar
Armycop
Old May 13, 2009 | 09:07 PM
Gene Culley's Avatar
Gene Culley
Premium Supporting Vendor
Thanks for the referral. I would be happy to help anyone out.
Old May 14, 2009 | 01:26 AM
DeeGee's Avatar
DeeGee
Its caused by sulfur build up on the sensor in the tank. If you catch it early with a fuel system cleaner such as techron it will remove the deposits and the gauge will begin working again. If the deposits are too heavy it needs a sensor change
Old May 14, 2009 | 08:53 PM
NemesisC5's Avatar
NemesisC5
Thank you for the information...how's the weather in England?
Old May 14, 2009 | 11:31 PM
grayfox2424's Avatar
grayfox2424
I used Seafoam ( WALMART*) and it worked for me..also in the past I used Chevron techtron which also worked...i did double up on the recommended amount..Sulfur in the gas is the problem . You should not have that problem if you use Chevron on a regular basis.
Old Mar 8, 2024 | 03:22 PM
ijakie1's Avatar
ijakie1
Any more info on this gene culley? Should we do a internet for "gene culley"?
Old Mar 8, 2024 | 08:11 PM
Try Cultrag Performance. 2009 thread closed.
To fuel level sensor replacement
