Parking light problem...pics
The light that I am talking about that's blown is the one that comes on when no other lights have been manually turned on. When you are driving down the road, the two orange lights appear up front. The passenger side one is out (which is one of the filiments inside the dual filament bulb). New bulb and it still happens. What gives?
I believe the turn signals are on seperate fuses since they have to operate independantly.
a blue/white wire which is the hot for the turn signal filament
a brown wire which is the hot for the parking light filament
a black wire which is the common ground.
The DRLs feed the turn signal circuit through the A2 fuse (underhood) and relays 38 and 40 (footwell).
If the DRL on the other side is working then its not a fuse issue or it would be dead too. That makes me think its at the light unit. Start the car and let the parking brake off to activate the DRLs. Put a multi meter on and check if you have power at the lamp. If so its a bad bulb. If not it could be a connection at the lamp unit or corrosion/dirt. Beyond that you'll need to troubleshoot upstream.
You could switch relay 38 and 40 on the footwell fuse panel. If its a bad relay it will switch the problem to the other DRL bulb.
Here's the circuit diagram to help troubleshoot.
I just replaced my passenger side light and had to replace the socket, too, as it looked like it had suffered from overheating.
Be sitting down when you find out the price for the socket. <g>
dan
