Solved; Stuck Tilt Steering C5
My wife apparently pulled back on the tilt steering lever without holding on to the steering wheel; and the spring load caused the tilt steering to become wedged in the uppermost position.
I used many of threads for the steering column lock as guide and I did not have the time to set up for pictures, so I will describe the process and you can hunt for some images to get you started.
This was the site I referenced:
http://www.vetteweb.com/tech/vemp_08...air/index.html
The problem is caused by two metal tangs that are spring loaded and can wedge against the steering column. The tilt lever works, but the steering wheel remains in the upper position.
First, remove the knee panel underneath the console on the drivers compartment. You will need to pry out the headlamp switch and the ignition light and locate some torx retainers; as well as a pair of torx retainers on the lower surface. I found that fully disassembling the ignition light -- wiring, plate and bulb holder made the removal easier. Pay attention as you will need to wiggle the knee panel from around the ignition switch and console.
The lower cover on the steering column just snaps off.
In Photo #8 the technician is tapping on the column lock. The tilt column mechanism is just behind the lock. Two tangs are sprung with a downward pressure towards the lower portion if the housing.
Using a screwdriver you will find that usually one of the two tangs swings free while the other is wedged. Use a small hammer and litghly tap the tang free; check the tilt; and reassemble.
HTH, Mike W
A couple notes:
1. It's much easier to remove the knee panel if you disassemble the center console first. Otherwise, it's a pain in the *** to get the temperature sensor out. It's even harder to get the sensor back in.
2. In addition to being snapped together, the top and bottom halves of the steering column cover are hooked together (at the forward-most part). To separate them, unsnap the rear-most parts simply by pulling them apart. Once those are apart, push the bottom half of the cover towards the front of the car and it should unhook from the top half. To remove the lower half of the cover, you will need to maneuver it around the steering column adjustment lever. What I did was rotate front-most part of the cover upwards. You'll see what I mean when you get there.
That's good to know.
