Reusing exhaust gaskets
Old May 20, 2009 | 01:06 PM
texdgl's Avatar
texdgl
Default Reusing exhaust gaskets
I plan to swap my 04 cpe exhaust (h-pipe & rear) for one from a 03 Z06 this weekend. The dealer will have to order the gaskets (approx. $21/ea for the front seal and $12/ea for the rear). Are the odds decent that I could reuse the existing gaskets. Is there something special about these gaskets to make them so pricey? Also, does anyone know if the h-pipe will bolt up the same (same length & sensor location) as the 04 exhaust since the Z06 does not have the pre-cats? Thanks.
Old May 20, 2009 | 01:40 PM
Todd157k's Avatar
Todd157k
Banned Scam/Spammer
I don't know about the H pipe but I wouldn't use old ex. gaskets. They compress and therefore shouldn't be used again.
Old May 20, 2009 | 04:05 PM
Cirrus8's Avatar
Cirrus8
When I changed out my cat back exhaust, I re-used the gaskets. That was several years ago and they are still gas tight.
Old May 20, 2009 | 04:15 PM
J S Machine's Avatar
J S Machine
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17
St. Jude Knife Maker
If I am not mistaken, the front up near the manifolds are ball gaskets. I wouldn't think you would need to replace those.
As far as the rear, take a screw driver or something of that nature and scrape all the insulating material off of both sides of the old gasket. The metal perforated piece will remain that was in the middle. Go to your local auto parts place and pic up some high temp super bad awesome RTV silicone gasket maker . The stuff I used was copper colored and may have even had copper in it if I remember correctly. Put a generous amount on both sides of the metal piece, and bolt everything up. YOU MUST LET IT DRY. once it sloidifies it will be as good or better than the original gasket.
Did mine this way a while back and no leaks or problems so far
edit-just saw where you mentioned "pre cats". I'm pretty sure that the H-pipe is the same on all of the cars, Z or not. I may be wrong, but I'm pretty sure they are the same.
Old May 20, 2009 | 05:14 PM
SeanMounce's Avatar
SeanMounce
I re-used my rear gaskets when I installed my axle back exhaust, no problems yet.
Old May 20, 2009 | 05:28 PM
z06 hellcat's Avatar
z06 hellcat
reuse them!
Old May 20, 2009 | 05:46 PM
texdgl's Avatar
texdgl
Thanks for the replies. I'll gamble on using the existing gaskets. I can always change the gaskets using ramps/jack stands at a later time if needed without having to drive to my brothers garage to use his lift. The h-pipes, on the later models anyhow, are indeed different since the they went with small pre-cats on the later years at least for the non-Z06 models. Not sure if there is a performance penalty for the systems with the pre-cats but I assume there is since the Z06's did not have them and I believe the cats themselves are different internally.
Old May 20, 2009 | 07:54 PM
dobewillie's Avatar
dobewillie
good luck with you decision
To Reusing exhaust gaskets
