water
Old May 22, 2009 | 05:30 PM
exusjs1's Avatar
exusjs1
1st Gear
Default water
help, I have an 04, vette that leaks water on the drivers carpet in the rain. Why i can't find any leaks on a car with only 34,000 miles on it. this happens while parked.
Old May 22, 2009 | 10:16 PM
Could be that your window is not contacting the weatherstripping tight enough, you might have a leak from the windshield or some other problem. You could try this - take the seat out and have someone run water over the car while you are inside. You might be able to see where water is coming in. If it is from the window area, you may be able to adjust the window tip in enough to stop the leak.
Old May 22, 2009 | 10:35 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I would be willing to say your udders under the hood on the firewall are plugged on the drivers side......
Old May 23, 2009 | 12:12 AM
jrose7004's Avatar
jrose7004
Try cleaning your udders.
To water
