New switch, same problem.
Old May 23, 2009 | 05:43 PM
mfastert's Avatar
mfastert
Default New switch, same problem.
I bought a new switch cuz my old one melted slightly and the headlights wouldn't turn off. I installed the new switch and the headlights turn off now, however they still don't turn on all the time (it's a problem I've had since I bought the car 3 years ago). If I click em on slowly it doesn't work, if I click it fast (not hard, just fast) they turn on. I have never had the problem that most have with the switch, where the lights turn off while driving. What is the deal?
Old May 23, 2009 | 06:31 PM
ljthe2nd's Avatar
ljthe2nd
Are you using the stock lighting, with stock bulbs? Has anything been added, like aftermarket fog lights, etc.?
Old May 23, 2009 | 07:13 PM
mfastert's Avatar
mfastert
It has the white bulbs or HID, I think that is what they are called. They were on there when I bought it. I have fog lights but they are not after market.
Old May 23, 2009 | 09:27 PM
ljthe2nd's Avatar
ljthe2nd
Do you mean you have stock headlight housings with aftermarket HID ballast and bulbs?
Old May 23, 2009 | 10:25 PM
mfastert's Avatar
mfastert
Stock housing, just the aftermarket bulbs. I have an alarm and remote starter too that came with it, I don't know why a Vette needs a remote start though. Thought maybe that could have something to do with it since it is attatched to lights as well.
Old May 23, 2009 | 11:35 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
what aftermarket bulbs did you use? wattage?
Old May 24, 2009 | 10:48 AM
mfastert's Avatar
mfastert
I don't know, they came with the car when I bought it. I know they are the HID cuz when they are off you can see the blueness thru the lense and when they are on they are not yellow, more of the blue or bright white that go with the HID. Is there an easy way to find out?
Old May 24, 2009 | 11:00 AM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Yes.
If it's true HID, the bulb will be connected to a large silver/chrome box called a ballast. It's usually about the size of the average pocket camera. If it's a halogen bulb, it will plug directly into the oem wiring.
Just because the bulb is blue does not mean it's HID. Halogen bulbs coated with a blue tint will resemble HIDs in color output, but the tinting significantly decreases output. The Blue hue from HID bulbs is caused by a the concentration of various salts in the arc section.
Old May 24, 2009 | 01:18 PM
mfastert's Avatar
mfastert
Looks like just a Halogen bulb.
Old May 26, 2009 | 10:12 PM
mfastert's Avatar
mfastert
ttt
Old May 27, 2009 | 12:59 AM
DeeGee's Avatar
DeeGee
The reason for TheRadioFlyers question is because you said the original switch melted. That's not right and could be caused by excessive current on the circuit. Two switch failures is not unique but it's unusual. If the rest is stock it seems the bulbs are causing the problem. Maybe they are pulling too much current for the stock wiring. If your first switch melted you may be at risk of a fire so there's a safety issue here.
FWIW, I'd change the switch again but revert to stock bulbs and see what happens. You may want a qualified auto electrician to check it just in case there's a deeper problem
JMHO
Old Apr 19, 2010 | 03:06 PM
mfastert's Avatar
mfastert
This problem was also fixed along with flickering headlights when I reconnected my battery after winter storage.
Old Apr 19, 2010 | 04:53 PM
MG RED 99's Avatar
MG RED 99
JMHO
To what degree did your switch melt. I would suggest getting the factory bulbs from the auto parts store, and replace the current ones, just to see if this makes any difference. I don't want to read about a car fire on here. Also visaully check the wiring near the headlamps.
To New switch, same problem.
