I have 19" ccw's all around right now but like the look of a smaller diameter wheel up front, I also have the willwood big brake kit. My question is does anyone know if the 18" 505's would fit up front with these calipers? I have no closeups of the front wheel at this time but thought someone might have experience with this. Thanks
I might be interested in trading you my 18"x10" 505a's for your 19" 505a's
If CCW tells me they'll fit and assuming your wheels are in as new condition and polished with no coating I'd be very interested, thanks for the replies
no need yet, i'll check with them tommorow and i'm sure you will want high res pics of mine as well.
________________________________________ ___________________
road pilot:
We can make a 18x9.5 with a 1" lip front that will clear the brakes, however the 18x10 2" lip will not.
i have ccw sp 500s 19 x 11 up front and 19 x 13 out back with the wilwood big brake kit 14 in rotors with 6 piston calipers and my front wheels clear by a hair. I dont know about the 505a but it wouldnt work on mine if i put an 18 up front. Dont know if that helped but im bored at work.
thanks, mine is close as well, i just didnt know if it was somehow possible.
Melissa
CCW
Thanks Melissa, kind of what I thought, funny I went to call CCW and checked my post first, you people are on top of things, thanks for the reply.
guess i'll look to sell the fronts and order new ones, not in a super rush the 19's look good as well but i prefer the 18's overall.
You can simply measure the clearance form the brake to the rim. If you have over 1/2" then you can go to 18s. It's no all that hard to determine.
I have 505's in the front, you need to order them 18x10.5 with a big brake off set.You can fit anything in their.
