[Z06] Cam / Injectors Advice
Old May 24, 2009 | 04:09 PM
blazer427X3's Avatar
blazer427X3
Default Cam / Injectors Advice
Hi All,
I'm looking into doing a cam swap on an 02 Z06. The car has a set of long tubes and a Vararam but is otherwise stock. The two cams I am considering are the G5x3 2??/2?? .600/.610 112 LSA from LG motorsports or a TRak Camshaft - 231/234 .640/.590 112 LSA from IPS. Does anyone have any experience with either of these cams in terms of streetability and performance ? Also one person is telling me I should replace my stock injectors with 42# injectors, another person says not needed. Advice ??
B
Old May 24, 2009 | 05:01 PM
Tech's Avatar
Tech
Put in the G5X3, datalog... replace injectors if necessary. I doubt you'll need 42# injectors (but you might need 36#). You want the smallest injectors you can safely run.
Old May 24, 2009 | 05:50 PM
corvette8189's Avatar
corvette8189
i have the G5X3 112 in love it. it is very streetable and makes great power.
Old May 24, 2009 | 07:01 PM
sublime1996525's Avatar
sublime1996525
You don't want to go too big with the injectors. I went with 36# for my car which actually turn into about a 42# with the 4-bar system the ls's use.
Old May 24, 2009 | 07:13 PM
blazer427X3
Thanks for the info guys. The stock injector is a 28.5# isn't it ? Also, I am thinking about having the cam and tune done at LG Motorsports in Wylie, TX. at about the halfway point of a roadtrip. How much runtime is required to datalog ? I'm sorry for the dumb questions but I am not familiar with the datalog procedure. I spoke with Bobby at LG (nice folks there) and got a quote on the parts, labor, and tune for the install. They give a discount to forum members too by the way . I don't recall any mention of injectors or datalogging as part of the process. I suppose I should give him another call to clarify this. I don't want to run too lean for the 1,700 mile remainder of the trip and risk any damage.
Old May 24, 2009 | 08:34 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I started my latest mods at the mod level that your at now. I added Patriot Stage II heads, FAST 90 (home ported) 90mm TB (home ported) 42lb/hr injectors Caddy Racing lifters and a ENGLANDGREEN Whiplash cam Its in the 240 Duration 610 lift and 114+4 duration and I'm at 450 HP
Old May 24, 2009 | 09:17 PM
blazer427X3
nice
Old May 24, 2009 | 09:28 PM
DsC5's Avatar
DsC5
I ran the G5X3-114 for about 5 years with stock injectors -- no problems there.
Old May 26, 2009 | 04:01 PM
Tech's Avatar
Tech
Datalogging is part of the tuning process. Have no fear... Bobby and LG will take good care of you.
To Cam / Injectors Advice
