Pull Key, Wait ten seconds.....
Old May 24, 2009 | 08:50 PM
delta doug's Avatar
delta doug
Default Pull Key, Wait ten seconds.....
I get this now and then on my '99, anyone have suggestions?
Old May 24, 2009 | 09:44 PM
jacobsjp's Avatar
jacobsjp
If you don't get the "service column lock" message along with it, then it could just be a dirty resistor in the key. Clean the resistor with rubbing alcohol and see if it clears up.
Old May 24, 2009 | 10:32 PM
delta doug's Avatar
delta doug
many thanks!, I'll give that a try.......
Old May 24, 2009 | 10:36 PM
And if you don't have the column lock bypass already, get one.
Old May 24, 2009 | 10:41 PM
itzza427's Avatar
itzza427
Yes indeed,,,this COULD just be a prelude to getting stranded one day soon! It did this on and off in a very random scattered pattern ,,,and one day BAM,,left me stranded with the fuel cutoff!!
Old May 24, 2009 | 10:46 PM
cor'00vette's Avatar
cor'00vette
I had the same message the other day, did what it said and it never came back. From reading other post it seems to not be a problem but if some one really knows the reason behind this it would be nice to know.
Old May 24, 2009 | 11:19 PM
8VETTE7's Avatar
8VETTE7
Check your PM's.
Old May 25, 2009 | 02:22 AM
DeeGee's Avatar
DeeGee
Here's some essential reading for you
http://forums.corvetteforum.com/c5-t...ky-please.html
To Pull Key, Wait ten seconds.....
