LED Tail Light Bulbs
Old May 25, 2009 | 10:59 AM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
Default LED Tail Light Bulbs
Anyone have any experience with these? I'm thinking of doing my tail lights with them. $22.00 for all four.
Old May 25, 2009 | 11:28 AM
overBlown's Avatar
overBlown
Old May 25, 2009 | 11:39 AM
turbocrazy's Avatar
turbocrazy
Old May 25, 2009 | 02:14 PM
catch06's Avatar
catch06
Question is whether a 19 light LED is enough if they are made cheaply. I did buy some LED's from a source other than oznium, and they weren't bright enough...just FYI.
Old May 25, 2009 | 02:21 PM
jdmvette's Avatar
jdmvette
Night Owl for life
not worth it.
Old May 25, 2009 | 02:27 PM
NorCalVette Kid's Avatar
NorCalVette Kid
St. Jude Donor '09
Originally Posted by jdmvette
not worth it.
Buddy of mine had it on his and they were not bright enough. Waste of money IMO. Plus you're gonna need something for the hyper flash if you don't have it already.
Old May 25, 2009 | 07:55 PM
Mark C5's Avatar
Mark C5
Thanks for the info
Old May 27, 2009 | 12:51 PM
j_digi454's Avatar
j_digi454
I just installed these, they are equal or brighter than the stock tail lights. Look awesome.
You do need to add the load resistors provided to prevent hyperflash.
http://forums.corvetteforum.com/c6-c...-kit-sale.html
Old May 27, 2009 | 01:36 PM
ljthe2nd's Avatar
ljthe2nd
I would not use those bulbs they won't be bright enough, but these are http://forums.corvetteforum.com/c6-c...-kit-sale.html
I have also installed those in my car. They are brighter than stock tail lights BUT I have clear lenses on my car. I did not install load resistors, instead I installed a bypass flasher that included an electronic flasher. No hyperflash, they are fantastic. Here's some pics at night I'll post some daytime pics if it ever stops raining.
These are pics with just the lights on, not the brakes.
Old May 27, 2009 | 01:41 PM
j_digi454's Avatar
j_digi454
I have the stock C6 Red Tail Light lenses and they are as bright as the original bulbs. I did one side only and liked what I saw.
You mention adding a bypass flasher, is this for a C6? I'm very interested in doing the same if it is for a C6. Any info would be appreciated. Thanks.
Old May 27, 2009 | 01:54 PM
ljthe2nd's Avatar
ljthe2nd
No its for the C5, It bypasses your stock flasher and uses an electronic one that works with LEDs. I don't know if they make it for the C6. Do a search for "flasher bypass harness" without the perenthesis and you will find quite a few examples.
Here one place to buy it for the C5 as I said I don't know if it works on a C6
http://www.corvette-enhancements.com/c5_flasher_fix.php
Old May 27, 2009 | 02:01 PM
j_digi454's Avatar
j_digi454
Riichard does not supply the harness for the C6, I already contacted him, it seems that the C6 might not have a flasher at all but might be controlled by the computer. I have all the manuals and nowhere is a flasher referenced. I'm concluding that I will have to use the load resistors whether I like it or not.
Old May 27, 2009 | 05:38 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Looks okay! and above looks like they work good so maybe not so bad a deal
Got a link?
Thanks,Matt
To LED Tail Light Bulbs
