C5 Vette A/C problems
Old May 25, 2009 | 11:34 AM
FLASHGLS's Avatar
FLASHGLS
Default C5 Vette A/C problems
I have a 97 C5 with the Auto dual climate control, the drivers side blows hot air and the passenger side blows cold air. ?
Old May 25, 2009 | 11:36 AM
jrose7004's Avatar
jrose7004
My 98 used to do that when it needed freon.
Old May 25, 2009 | 11:40 AM
FLASHGLS's Avatar
FLASHGLS
Default reply
I never thought about that, Did you have to take it in for service? and what is the level it should be? I have heard there is two different amounts.
Old May 25, 2009 | 11:45 AM
jrose7004's Avatar
jrose7004
No I would put the freon in myself. I finally had a shop fix the leak though.
Old May 25, 2009 | 11:47 AM
glkfam's Avatar
glkfam
I thought somewhere on the forum guys said that this pertained to one of the vent doors sticking or not opening all the way. If you got cold A/C air out of one side, to me it has to be something to do with the vent doors leading up to the driver side outlet vent. Just a thought
Old May 25, 2009 | 11:50 AM
FLASHGLS's Avatar
FLASHGLS
Default reply
See thats what I would think. If the freon was low why would I get nice cold air from the passenger side? But what do I know..
Old May 25, 2009 | 11:52 AM
FLASHGLS's Avatar
FLASHGLS
Default reply
Does anyone know where the Vent door is located, that would separate the hot and cold on the drivers side?
Old May 25, 2009 | 03:37 PM
Pineapple1's Avatar
Pineapple1
Having the same problem. Where should I hook up a gauge to check the refrigerant pressure?
Old May 25, 2009 | 06:03 PM
jrose7004's Avatar
jrose7004
The vent door has something to do with the fuses, but freon charging always cured mine. You might try the search function.
Old Jun 11, 2009 | 03:56 PM
FLASHGLS's Avatar
FLASHGLS
It might not be the freeon after all, My problem was the Accuator deep in the dash, I replaced it myself. A/C works like a charm now, left me know if I can help you?
Old Jun 11, 2009 | 04:13 PM
bucwheat's Avatar
bucwheat
Is there any air coming from the vent not blowing cold?
Old Jun 11, 2009 | 04:41 PM
robsc501's Avatar
robsc501
Hi There:
The motor that FLASHGLS was talking about is gm p/n 89018365.It is called gm a/c actuator door flap motor. cost $ 263.47 at our local dealer.The question is: Is the door just stuck? or is the fuse blown? or a bad motor?
robsc501
Old Jun 11, 2009 | 05:42 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Have you checked your codes to see exactly what is going on?
You might have to do this, reindex your actuators:
http://forums.corvetteforum.com/c5-t...actuators.html
Here is another problem you might have or even run into in the future, when air comes out of all vents:
http://forums.corvetteforum.com/c5-t...with-pics.html
Thanks,Matt
Old Jun 13, 2009 | 06:38 PM
squidwards vert's Avatar
squidwards vert
Your actuators need to be re-indexed.
Disconnect the battery over night and reconnect it in the AM, it should solve the problem.
Has worked three times for me, stereo install, dead battery and engine install. Hot drivers side, cold passenger. Next AM, ice cold both sides.
Its free and easy, try it first.
To C5 Vette A/C problems
