brake light malfunction
Old May 31, 2009 | 02:19 PM
mragor's Avatar
mragor
Cruising
Default brake light malfunction
Question: My 2000 convertible, right rear, turn signals, tail lights work, but brake light do not. (replaced bulbs, no help)
Old May 31, 2009 | 02:20 PM
mickey_7106's Avatar
mickey_7106
any codes?
Old May 31, 2009 | 02:43 PM
mragor's Avatar
mragor
Cruising
Sorry, but where would i see a code? the only way i new i didn't have any, was my wife following me, and told me.
Old May 31, 2009 | 03:52 PM
J S Machine's Avatar
J S Machine
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17
St. Jude Knife Maker
Your codes would be in the DIC (Driver Information Center) above the steering wheel inside the instrument cluster.
Sounds like you may have a short. I'm not sure if that will throw a code to tell you or not.
Are you sure you tried new bulbs, if so, check that same new bulb in one of the other sockets and see if it works there. If it does you know something is wrong with the wiring or the socket you were concerned about to begin with. You might try wiggling some wires around a bit or being sure the socket isn't corroded. Another thing is to be sure the bulb is seated firmly in the socket. It may go down and snap, but not be all the way in. This will cause it to do exaclty what you are saying.
Use a sock or a towel to hold the bulb so that if you push to hard and it breaks it won't cut your hand. wiggle it back and fourth a little as you are pushing and this may ease it up a little
Old May 31, 2009 | 03:54 PM
J S Machine
just reread your original post. Check your fuses too
Old May 31, 2009 | 04:45 PM
mragor's Avatar
mragor
Cruising
I'll check the fuse, I had already removed the new bulb replaced it, however did not try it in the left side sockets, which both do work. Also, i had wiggle wire, etc...
Old May 31, 2009 | 04:49 PM
mickey_7106
follow this link to pull the codes http://www.97vette.com/howto/codes/index.html
Old May 31, 2009 | 06:14 PM
Jet-Jock's Avatar
Jet-Jock
There is a ground harness connector that can been seen from the passenger side rear wheel well. Disconnect the connector and check for corrosion.
Old May 31, 2009 | 07:19 PM
dobewillie's Avatar
dobewillie
good luck with a fix
Old May 31, 2009 | 07:34 PM
mragor's Avatar
mragor
Cruising
Wouldn't the ground be ok, if the turn signal and taillights are working?
To brake light malfunction
