When to Replace Tires due to Age
Old Jun 5, 2009 | 10:40 AM
Originally Posted by AU N EGL
It depends on your type of driving. For hot rodding hard driving, every two years.
For normal driving, even on a performance car tires 5-7 years.
Tread life has NOTHING to do with traction.
rubber gets HARD and slippery with in a few years.
Old Jun 5, 2009 | 11:55 AM
Rich-L's Avatar
Rich-L
I replaced my stock run-flats on 04 conv. this year with GSD3's. The stock had 18k, looked good, pleanty of thread, but were hard as rocks. What a difference in ride and noise, if you can afford it don't wait it is worth the dollars. Your chose of tire of course.
Old Jun 6, 2009 | 06:08 AM
eylesda's Avatar
eylesda
Mine had Pirrelli P Zeros on when I bought it. The tyres were only 2 years old with very little wear but had tiny cracks all around the shoulder, the outer edge that is in contact with the road.
I presumed they were age cracks so ditched them for safety. Maybe they would have lasted but not worth the risk. Just my opinion.
Old Jun 6, 2009 | 06:37 AM
AU N EGL's Avatar
AU N EGL
One of the GOOD things about Older tires, if you ever wanted to TRY auto-crossing or go to a skid pad. Older tires would be great to TRY these events.
You wont runin NEW tires, but be able to slide slightly with these older tires.
I took a car with older tires, to a skid pad. WOW did I have fun No traction what so ever, so I could get that rear end to swing around with out much trouble. Working on correcting over steer, going semi slidewaise under control.
Then we OPEN the fire hydrent for a WET skid pad. Yipppyyyyy oh that was even more fun.
Car was a 91 Camaro
