Rapid temp increase
Old Jun 5, 2009 | 01:43 PM
midlifetoy1's Avatar
midlifetoy1
Default Rapid temp increase
What could cause a rapid tem increase in coolant temp? I've noticed that my temps have been running higher than what has been said to be the normal range and plan to pull the radiator shroud tomorrow to check for any blockage and possibly change the thremostat. Yesterday I reprogrammed the fans to come on sooner and this has helped, but this morning I started the car and the temp read 80 degrees and by the time I got to the end ofthe driveway the temp was up to 85. In less than a mile it had risen to 180 plus. No I didn't have my foot in it, no faster that 30mph.
Could this be an indication of air in the system or a bad thermostat. I've been under the car and did not see any major blockage. I also have not noticed any problem with the coolant tank cap.
I really need ya'lls help with this
Thanx
Old Jun 5, 2009 | 03:55 PM
bucwheat's Avatar
bucwheat
Check to see if you picked up a plastic bag,these bottom feeders pickup all sorts of things ,if you have never looked up into the radiator core you are in for a surprise.
Old Jun 5, 2009 | 03:57 PM
4U2ENVY's Avatar
4U2ENVY
From: Obama says I'm a bitter white guy clinging to my guns and religon and he's right
Possible you have an air bubble. Perhaps you need to burp it.
Old Jun 5, 2009 | 04:04 PM
MagRedConv's Avatar
MagRedConv
So what was the highest temp it reached?
Old Jun 5, 2009 | 04:11 PM
stingraymyway's Avatar
stingraymyway
From: Out of Site...Out of Mind. Corvette: anything else is just transportation.
St. Jude Donor '09 thru '20
Beat me to it.
Old Jun 5, 2009 | 05:16 PM
midlifetoy1
Default temp increase
on the first ocassion it reached 250 sitting in heavy traffic with outside temp at 90+. The next day I checked for debris blocking the radiator. I did this from under the car. After that it would get up to about 235 in regular traffic. As stated earlier, I reprogrammed the fans to come on at 195 and it has helped as the temp has only gotten to
215 sitting at a light but pretty much stays at 205 (but the outside temp has only been about 80)
Old Jun 5, 2009 | 05:28 PM
MagRedConv's Avatar
MagRedConv
I had an issue a while back where my temps would rise to 245 sitting. I knew this was wrong regardless of the "our cars run hot" posts. Turns out the water pump was shot. No leaking or noise to give a hint. Replaced the part and all is well.
Old Jun 5, 2009 | 05:29 PM
99mallett's Avatar
99mallett
From: The line waiting to see Santa Claus stretched all the way back to Terre Haute, and I was at the end, Indiana
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
I'd bet it's crap in the radiator. You have to stick your head under the front and look way up to the top 1/3 of the area.
I have found plastic bag pieces, cigarette butts, styrofoam pieces, candy wrappers, grass/weed cuttings, corn stalk pieces, and all kinds of other crap in the 10 years I have owned my C5.
I usually clean it out in May or June and again in the Fall.
Old Jun 5, 2009 | 08:39 PM
midlifetoy1
Default temp
I looked from the bottom and will be pulling the radiator shroud tomorrrow. Could it be an air bubble or a bad thermostat? the water pump was replaced last year.
Old Jun 5, 2009 | 09:23 PM
sneakelman's Avatar
sneakelman
The thermo has possibly stuck semi shut.
Old Jun 5, 2009 | 09:42 PM
canecorso69's Avatar
canecorso69
Thermostat. Mine did the exact same thing yours is doing. I replaced thermostat and havent had a problem since. Good luck.
To Rapid temp increase
