Check engine light
Old Jun 5, 2009 | 11:31 PM
cosner57's Avatar
cosner57
4th Gear
Default Check engine light
I bought a 2004 two months ago. I drove it for about 600 miles so far. It had 4070 miles on it when I got it. I took it to my local Chevy dealer thinking it would be a good idea to get it completely serviced and checked over. I had all the fluids and everything changed in it. I bring it home and drive it about 20 miles and the check engine light has came on. Any ideas or do I just take it back to the dealer for them to check over again. The service dept. said that I could drive it over the weekend as long as the light doesn't start blinking. Is that OK?
Cos
Old Jun 5, 2009 | 11:38 PM
vette.mix's Avatar
vette.mix
Get the codes and go on the tech forum
Old Jun 5, 2009 | 11:39 PM
8VETTE7's Avatar
8VETTE7
I'm guessing that you don't know how to pull the DTC's so here a cut and paste from a Bill Curlee post on how to go that.
READING YOUR Engine Diagnostic Trouble Codes (DTC)
This procedure should be carried out any time you experience a problem with your C5. Most inexpensive store bought aftermarket code readers will ONLY read power train DTC’s. Reading the DTC’s with the C5 built in code reader will allow you to read ALL the modules in the vehicle.
The Diagnostic Display Mode is entered with the following procedure:
1) Turn on the ignition but don't start the engine.
2) Press the RESET button to turn off any warning messages. (i.e. door open, trunk open ect)
3) Press and hold the OPTIONS button
4) While holding OPTIONS, press FUEL button four times within a 10 -second period.
Initially, the on-board diagnostics go into an Automatic Mode which will cycle through each module and shows diagnostic codes in a pre-set sequence: PCM - TCS - RTD - BCM - IPC - RADIO - HVAC - LDCM - RDCM - SCM - RFA. All codes will be displayed for each module. ( i.e. PCM = 4 codes) If none are present in a given module, you will see No More Codes on the display.
There are two types of diagnostic codes, Current and History designated with a letter suffix, “C” or “H”. A current code indicates a malfunction is present in the module displaying data. A history code indicates a problem existed sometime in the last 40 or 50 ignition cycles. When not accompanied by a current code of the same number, it's potential evidence of a previous problem, now resolved, that was not removed by clearing the codes. More likely it's an indication of an intermittent malfunction.
Intermittent codes are the most challenging of the diagnostics. An intermittent code may have happened once, may have happened more than once but is inconsistent or may be happening on a regular basis but not at the time the codes are displayed. History codes can also be caused by a current malfunction in a system that is not operating at the time codes are displayed. An example is the rear window defogger which doesn't operate until the Body Control Module detects engine rpm. For history codes set by a module that does not operate with the key on and engine off, a special diagnostic tool called a Scan Tester is necessary to properly diagnose the malfunction.
Once the system has displayed all modules, it goes into the manual mode which allows selection of each module using combinations of Driver Information Center buttons. Manual mode can also be entered during the automatic sequence by pressing any button except E/M. Once the display shows Manual Diagnostics, select a module by pressing the OPTIONS button to go forward or the TRIP button to go back. Once a module is selected, a code is displayed, and if more than one are present; press GAGES to go forward or FUEL to go back.
To exit the diagnostic mode at any time, press E/M. If you want to erase codes in a given module, press RESET To reset the codes once in manual mode, press and hold RESET until it displays NO CODES Press OPTIONS to go to the next module. Repeat the steps until you have reset the codes in all the computer modules.
NOTE!! Only reset the codes IF you want to - it is NOT necessary to do this. Clearing a code does not repair a problem. You are simply erasing the evidence of it in the module's memory. If you clear the code/s, and extinguish the Check Engine Light, your emissions status ready will NOT allow you to pass an emissions test until you have completed the required driving cycles. There are a few body module DTC’s that if set will prevent the module from operating properly. Once the DTC is cleared, the module will return to full function. This is not true for power train DTCs.
If you have never read and cleared your codes, there will probably be a lot of old history DTCs. It is recommended that you clear your codes and see if any come back during a driving cycle. Those are the ones that you need to concentrate on diagnosing.
Once you have the codes, the next question is: What to do with the information?
First, consult the factory service manual. Any serious C5 Do-It-Yourself owner should invest in the Corvette Service Manual of the appropriate model year. The Service Manual is really a requirement if you want to understand and work on your C5.
These are some very good C5 Diagnostic Trouble Code (DTC) explanation web sites!!! They also explain how to read the DTCs
http://www.corvettedoctor.com/Code_Main.html
http://www.corvettedoctor.com/index.html
Go to “technical data base” and then to “Corvette ECM Computer Codes”. Then select your year car. Read the instructions and then scroll down to the "READ MORE" window to view the code definitions.\
Here are some more very good sites:
http://www.gearchatter.com/viewtopic11755.php
http://www.obd-codes.com/trouble_cod...d-ii-codes.php
Make sure to include the H or C suffix when you post your DTCs
Jot down what shows and then clear them all. Drive the car at least several miles ( Check engine light should not hurt anything unless you drive many hundreds of miles with it on)
Then pull the codes again and post what you have. Be sure to include the H or C with the code.
Old Jun 5, 2009 | 11:48 PM
vette.mix's Avatar
vette.mix
I knew someone would post how to pull the codes, now I have it saved
Old Jun 6, 2009 | 12:11 AM
guitar420911's Avatar
guitar420911
Any mods?
Old Jun 6, 2009 | 12:39 AM
urfubar's Avatar
urfubar
mine threw a code once 'cause i didnt tighten the gas cap enough...you should be fine brother...and once you pull the codes there are ALOT of smart guys on here (i am still learning) that can tell you how to fix it or where you need to go to get it fixed!
To Check engine light
