rear side marker
Old Jun 7, 2009 | 11:25 AM
80vetla's Avatar
80vetla
Default rear side marker
My rear side marker housing broke and today im changing it out. Was wondering whats going to be the easiest way to get to the back to take the nuts off to change? wheel well? thanks
Old Jun 7, 2009 | 11:48 AM
vettes&hockey=life's Avatar
vettes&hockey=life
This should help.
http://www.spdkilz.com/techtipsidemarker.html
Corey
Old Jun 7, 2009 | 11:50 AM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Remove tail light.
Old Jun 7, 2009 | 11:58 AM
80vetla's Avatar
80vetla
Wow! glad i asked because i would have never thought of that! thanks guys!
Old Jun 7, 2009 | 11:59 AM
DeeGee's Avatar
DeeGee
Just pull the tail light and reach in. Here are some pics that will help
I see you have a Vert. If it's the passenger side its a little harder as the antenna gets in the way. It's a bit of a squeeze that side.
Old Jun 7, 2009 | 12:01 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
And be very gentle when you tighten the nuts on the plastic pegs during the re-install. They will snap very easily if overtightened.
Old Jun 7, 2009 | 12:02 PM
DeeGee's Avatar
DeeGee
Originally Posted by Blue 92
And be very gentle when you tighten the nuts on the plastic pegs during the re-install. The will snap very easily if overtightened.
A very good point
BTW love the 10 Year member icon
Old Jun 7, 2009 | 12:11 PM
Blue 92's Avatar
Blue 92
Originally Posted by DeeGee
A very good point
I learned that one the hard way. The flip side is that they will stay in place with only only one post left.
I've met a lot of great people through CF.
Old Jun 7, 2009 | 09:37 PM
krm_wi_C5's Avatar
krm_wi_C5
The side with the antenna is a little tricky, I ended up going in through the wheel well.
Old Jun 7, 2009 | 09:48 PM
ALLEGRO's Avatar
ALLEGRO
Having replaced mine to amber, I can tell you that it is WAY easier to remove the outer tail lamp than to work you arm around the muffler can. I loosened the muffler mounts on the frame-rain and ALMOST lost the hanger bolt inside the bumper bar. VERY close call.
Old Jun 7, 2009 | 09:55 PM
Originally Posted by Bill K
Remove tail light.
That's how I changed mine out when one of the pegs broke. Wasn't hard to do, but , do be careful when tightening the nut down on the plastic stud - too much pressure and it will twist off.
Old Jun 8, 2009 | 10:00 AM
clif's Avatar
clif
St. Jude Donor '09-'10
I have a 99 vert... I changed the left side through the tail light hole. The right side is another story! There is a huge antenna in the way! I am going to pull the right rear wheel liner to change this one.
Old Jun 8, 2009 | 10:19 AM
bucwheat's Avatar
bucwheat
Nice trick to remember.
Old Jun 8, 2009 | 05:45 PM
Blue 92's Avatar
Blue 92
I the right side from underneath. Piece of cake since SLP Loudmouth = no mufflers in the way.
To rear side marker
