C5 trouble code 10PCM P0442 HC
Old Jun 8, 2009 | 12:03 PM
red2001c5's Avatar
red2001c5
6th Gear
Default C5 trouble code 10PCM P0442 HC
Can anyone tell me what this code means. It is not on the list of codes at http://www.stengel.net/diccodes.htm
Old Jun 8, 2009 | 12:19 PM
poolboy's Avatar
poolboy
Check to ensure your gas cap is on tight - http://www.gearchatter.com/viewtopic10457.php
Old Jun 8, 2009 | 01:51 PM
urfubar's Avatar
urfubar
yeah....same code came up...and you must tighten the cap at least 3-4 clicks....i found out the same way as you....
To C5 trouble code 10PCM P0442 HC
