transmission temps
Old Jun 8, 2009 | 01:42 PM
RON NARDONE's Avatar
RON NARDONE
Default transmission temps
What is the normal range of temps.of the transmission? At what temp. should you start to think about having your transmission looked at??
Old Jun 8, 2009 | 01:57 PM
rrichar2591's Avatar
rrichar2591
If I remember right, the transmission fluid temp on the DIC usually reads around 174 degrees. Hope this helps answer the questions.
Old Jun 8, 2009 | 02:12 PM
Dominic Toretto's Avatar
Dominic Toretto
I've noticed mine can exceed 200F on a hot day ambient temps being around 95F. I was told by a rep at LGM that transmission fluid does not begin to breakdown or oxidize around 260F.
-Alex
Old Jun 8, 2009 | 02:22 PM
RON NARDONE
-Alex
ive gotta watch mine Idont think ive ever hit 200 thanks Alex
Old Jun 8, 2009 | 02:27 PM
Bluefire's Avatar
Bluefire
I converted my A4 to 3:42's and a 2800 stall. Even, in 90+ degrees and driving hard my trans temp stays ~ 175 - 180 degrees. HTH
Old Jun 8, 2009 | 02:32 PM
Dominic Toretto
Originally Posted by Bluefire
I converted my A4 to 3:42's and a 2800 stall. Even, in 90+ degrees and driving hard my trans temp stays ~ 275 - 280 degrees. HTH
I'd worry if mine were near 300 degrees.
-Alex
Old Jun 8, 2009 | 02:34 PM
AU Eagle's Avatar
AU Eagle
St. Jude Donor '08-'09-'10-'11, '14
190 degrees, it was 82 out, running 70 mph for a few hours 2.73 axle
Old Jun 8, 2009 | 02:40 PM
ALVETTE00's Avatar
ALVETTE00
Prior to doing the 2800 stall on my A4 175-190 was typical operating range.
After doing the stall, it would spike up to 220-230 very quickly if pulling lots of hills or when putting my foot into it...and take a long time to cool back down.
Added tranny cooler and now it's back to the pre-stall range!!!
To the OP...if you're seeing 275+ temps...you're doing harm...get a tranny cooler
Also, if you have a stall run in 3, not D around town...and your converter should lockup(assuming you have a lockup converter) at a slower speed thereby reducing heat.
Old Jun 8, 2009 | 02:41 PM
renegad44's Avatar
renegad44
From: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
Mine, on the highway, during our treacherous summers has run between 165-188. City driving in the summer increases it quite a bit.
Old Jun 8, 2009 | 02:46 PM
KenShores's Avatar
KenShores
I've been wondering the same. I have checked mine many times while driving around and it seems to stay close to water and oil temps. If I do a bit of shifting then it climbs a little higher. I have A4, standard everything.
I could not find anything in the owners manual about temps, but you can see what they are.
I think the highest I've been is about 210 when other temps can be 220 or so. When just cruising down the hwy, my trans temps seem to run lower than water, oil, maybe by 10-20 degrees.
On hot days and sitting in traffic my trans temps seem to get to the highest, but I don't think I busted 220. Water has been 220 plus on hot days.
thisMSGgood4me's Avatar
thisMSGgood4me
I usually see high 100's max, have never seen it in the 200's even on a hot day and driving it a little hard. Typically around 175 under normal driving conditions.
Old Jun 8, 2009 | 09:15 PM
Bluefire's Avatar
Bluefire
-Alex
Good catch. Thankfully it was a typo I meant 175 - 185.
Old Jun 8, 2009 | 09:21 PM
Dominic Toretto
That's better
-Alex
Old Jun 8, 2009 | 09:29 PM
Optimus_C5's Avatar
Optimus_C5
From: If opportunity doesn't knock, build a door. South West Florida / Livin' The Dream
St. Jude Donor '12
Im running a RPM stage IV tranny, B&M cooler, a Yank SS3200 stall and 3:42 gears and I'm between 190 to 210.
Old Jun 10, 2009 | 09:01 AM
bucwheat's Avatar
bucwheat
Can't figure out why my DIC reads HIGH TRANS TEMP then posts 174 degrees.
Old Jun 10, 2009 | 09:09 AM
Dominic Toretto
Bad sensor mayhaps?
-Alex
Old Jun 10, 2009 | 09:51 AM
DuronClocker's Avatar
DuronClocker
Driving around yesterday in 75*F weather, I saw a high of 201*F. Its usually in the 180s or 190s when fully warmed up and driving around town. Haven't beat on it for a long enough time at once to see it go any higher.
To transmission temps
Old Jun 10, 2009 | 12:06 PM
urfubar's Avatar
urfubar
What transmission fluid brand do you guys run and how many quarts does it take to change over to say royal purple on a stock C5 MY 01'?
Old Jun 10, 2009 | 03:19 PM
Dominic Toretto
You'll want to do a complete flush which would include up to 12 quarts.
-Alex
Old Jun 10, 2009 | 03:53 PM
Bluefire's Avatar
Bluefire
-Alex
I have heard that you never want to power flush an auto transmission. You could knock loose built up tarnish from the inside and it could clog up your valve body. I'm not a A4 expert, but I would like to know if it is true.
