Helllpp!!!
Old Jun 11, 2009 | 12:27 AM
rosiescowboy's Avatar
rosiescowboy
Default Helllpp!!!
I am trying to buy an '01 in utah and bringing it into calif it has a halltech intake. Will it pass smog?? 35k miles!!
ANYONE?????
Thanks!
Old Jun 11, 2009 | 01:06 AM
soggysailor's Avatar
soggysailor
Either buy or borrow a stock intake and reinstall. Switch it back when done and you're good for 2 years. EZ to swap these in and out. I do every 2 years and use the change out time to service the Halltech. Good luck!
Old Jun 11, 2009 | 01:12 AM
DuronClocker's Avatar
DuronClocker
If it doesn't I'll trade you the stock intake off my car It was even originally a CA car
Old Jun 11, 2009 | 01:20 AM
CorvetteAddict's Avatar
CorvetteAddict
if it's just a different intake, chances are they won't notice. I had to get a smog check done during spring break (I installed a hurricane filter element from WCC). The tech didn't notice and I didn't have any problem passing. you could always check out halltech's website and see if their intake is 50 state legal. Or you could do some quick googling and find a list of CARB exemptions, you can filter by make and model I believe so it shouldn't take too long
Old Jun 11, 2009 | 05:21 AM
PostShawn's Avatar
PostShawn
When I got mine smog checked they visually noticed it. He was nice and said he will pass me but if my intake isn't stock or doesn't come with a CARB number next time it wont pass. The Halltech says Halltech on it and that's what usually gives it away as an aftermarket part. The only two intakes technically legal in CA as I understand is K&N and the Callaway because they both have CARB numbers. I was tempted to put a K&N sticker on my Halltech but I'd still need a CARB sticker somewhere for it. Luckily I passed anyway.
They are easy to swap out so you can just get a stock intake and put it on for the test.
Best of luck.
Old Jun 11, 2009 | 07:18 AM
MagRedConv's Avatar
MagRedConv
Why not call Halltech and get the CARB number? It may very well be on their site as well.
Old Jun 11, 2009 | 11:05 AM
bucwheat's Avatar
bucwheat
I trashed mine,or I could have sent it to you.
Old Jun 11, 2009 | 02:55 PM
Dave68's Avatar
Dave68
Halltech's intake systems are NOT CARB-approved, so a simple swap operation is necessary when smog-check time rolls around.
Old Jun 11, 2009 | 02:56 PM
MagRedConv's Avatar
MagRedConv
Didn't know that. So he just needs to hit the Parts board and pick up a stock assembly.
To Helllpp!!!
