Shifter Problem, Not typical
Old Jun 11, 2009 | 03:45 PM
transamer79's Avatar
transamer79
Default Shifter Problem, Not typical
I just put 3.90 gears in my car last night and at about midnight we finished putting everything back together. We took the shifter out because we were planning on changing the torque tube bushings but didnt because of the project intailed in removing the down pipes for the turbos. Anyways.... We put the shifter back in and it wont go into all of the gears. I already searched the whole forum and tried every suggestion including putting the pin in and locking the shifter in neutral and lostening and retightening the torqx. That didnt work and i tried tightening the torqx with the shifter in different positions and that didnt work either. When the car is off i can get the shifter into every gear but reverse but when i start the car it will only go into 1st 4th and 6th. It is an aftermarket Kirbin short throw. Any suggestion would be welcome. Kevin
Old Jun 11, 2009 | 03:51 PM
homewrecker's Avatar
homewrecker
Put in the stock shifter to see if you could get it into all the gears. Those Kirbin short throws has more notches than my headboard.
Old Jun 11, 2009 | 04:02 PM
transamer79
lol thanks, but i dont have a stock shifter
Old Jun 11, 2009 | 04:55 PM
homewrecker
ttt help for our stranded brother!
Old Jun 11, 2009 | 07:18 PM
transamer79
thanks bro. Im still trying to figure it out. I changed the trans fluid last night but i dont think that would do it.
Old Jun 11, 2009 | 09:20 PM
homewrecker
There's gotta be a stock shifter around in NY. It doesn't make sense since you can put it in gear with the engine off...wtf? I'm racking my brain and maybe someone else that drank less coffee will chime in. TTT!
Old Jun 12, 2009 | 07:23 AM
transamer79
im still having no luck. Im gonna steal my friends short throw off his 99 today and see if that helps.
Old Jun 12, 2009 | 01:38 PM
transamer79
problem fixed. The speed sensor in the rear was cut so i got a new plug, spliced it in and now its perfect.
Old Jun 12, 2009 | 04:03 PM
homewrecker
Yes!!!! Have fun!
Old Jun 13, 2009 | 06:27 PM
squidwards vert's Avatar
squidwards vert
I have a kirbin as well, they are a very precise shifter, I love mine.
Glad you got it worked out
To Shifter Problem, Not typical
