Differental Fluid Question
Old Jun 12, 2009 | 08:24 AM
transamer79's Avatar
transamer79
Default Differental Fluid Question
Just put a new 3.90 rear in my car and the gentelman tha tbuilt it said put the OEM gear oil in. I went to the GM dealer and bought 3 quarts of what the parts manager said came stock in the c5. After reading some threads here i noticed that people are putting a limited slip addative in which i did not. Am i ok or am i supposed to add something else. The bottle i added reads..... Synthetic Axle Lubricant SAE 75w-90. Nothing on the bottle about addative. Thanks for the help.
Old Jun 12, 2009 | 08:55 AM
bucwheat's Avatar
bucwheat
Surprised the parts Manager didn't sell you the additive.You do have to add it to eliminate the rear chatter.
Old Jun 12, 2009 | 08:58 AM
transamer79
interesting. If there is no chatter do i still have to add it?
Old Jun 12, 2009 | 09:14 AM
DevilMan02's Avatar
DevilMan02
I'd have a few choice words for that 'service' manager.
Old Jun 12, 2009 | 10:32 AM
bgreen83's Avatar
bgreen83
I would just to be on the safe side. I had chatter and switched over to amsoil. I'd recommend that or royal purple since they both already have the limited slip additive mixed in.
Old Jun 12, 2009 | 01:36 PM
transamer79
just got back from the dealer and i put the addative in and took it for the first ride with new 3.90s. DAMN totally different.
Old Jun 12, 2009 | 02:05 PM
rmtt's Avatar
rmtt
Mine are going in soon. I can't wait.
Have you done any engine mods yet? I have H/C/I, and was told that gears will feel like I had that done all over again.
Old Jun 13, 2009 | 06:01 AM
transamer79
Car has turbos. Makes 525 at the tire. I like the gears but i think the 3.42 were better for turbo. My quatermile time was almost exactly the same with the new 3.90s and slicks compared to the 3.42s and street tires. Im pissed.
Old Jun 13, 2009 | 07:01 AM
J S Machine's Avatar
J S Machine
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17
St. Jude Knife Maker
Gotta have limited slip additive. I can't believe the parts guy didn't know this
Old Jun 13, 2009 | 08:46 AM
rmtt's Avatar
rmtt
Sorry to hear that. Mine makes nowhere near that (465).
I had always read that FI cars did better with 3:42's and less.
You should post about this over in the performance section. A lot of good guys over there that could probably help you figure out why this happened as there are a lot of variables involved.
Old Jun 13, 2009 | 09:43 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
I'm am glad to see you added the additive - you would not of enjoyed the resulting damage to your new 3.90's!
Enjoy and be careful
Thanks,Matt
Old Jun 13, 2009 | 09:52 AM
Tim01Coupe's Avatar
Tim01Coupe
You will chatter eventually with straight gear oil, and soon, and could damage the differential, it needs to slip a bit around corners because the outside tire travels farther than the inside tire, enough corners and you can do damage without the slip additive (friction modifier) the the Corvette is designed to have.
Your parts guy is an idiot, get a new one, he doesn't know jack about Corvettes....
Old Sep 22, 2009 | 09:51 PM
waunavet's Avatar
waunavet
St. Jude Donor '20
Yes, because there will be later.
Old Sep 22, 2009 | 09:53 PM
waunavet's Avatar
waunavet
St. Jude Donor '20
A second question on this topic..........when you pull the drain plug, should the fluid just seep out to be at the proper level?
Old Sep 22, 2009 | 10:15 PM
The NNIAL8R's Avatar
The NNIAL8R
St. Jude Donor '11,'13
"I voluntarily took 60 days off from OT"
Im assuming you mean the FILL plug...Yes, it should just be to the bottom of the hole.....Personally, I use TWO 4 ounce bottles of the limited slip additive...If your diff is completely full you'll need to drain some to make room for the additive.
Old Sep 22, 2009 | 10:34 PM
waunavet's Avatar
waunavet
St. Jude Donor '20
Yes, I meant fill plug. I fixed the leaky butt syndrone last month. Pulled the plug last night and the fluid oozed out the bottom of the hole. I used Mobil 1 fluid with the additive. Works fine and quiet too.
Old Sep 22, 2009 | 11:24 PM
ALLEGRO's Avatar
ALLEGRO
I am confused.
Was the original fill from BG a synthetic or dino? I thought that all the fluids were "high tech" ..... what gives?
To Differental Fluid Question
Old Sep 22, 2009 | 11:41 PM
The NNIAL8R
Originally Posted by ALLEGRO
I am confused.
The original fill is synthetic..but it still requires the limited slip additive...
Old Sep 23, 2009 | 03:10 AM
striper's Avatar
striper
The most recent version of GM's rear end synthetic lube does not require additional posi lube, it is built into the new fluid. The part # is GM 88862624 or AC # 88862625. Dan, you should have known of this because I think Bruce or someone else posted it a while ago on the C5registry.
Old Sep 23, 2009 | 07:31 AM
The NNIAL8R
Yes, I remember hearing something about it, but old habits are hard to break...I still use the old stuff...In fact, I havent seen any of the new stuff at my local GM parts dept....
