how much does a c5 wiegh?
Old Jun 18, 2009 | 09:14 PM
vettandtyphoon1's Avatar
vettandtyphoon1
Default how much does a c5 wiegh?
how heavy are your cars? in stock trim
i have a coupe and i'm trying to get an idea what my car wieghs.. with an iron block!!
Old Jun 18, 2009 | 09:23 PM
JEEP/C5's Avatar
JEEP/C5
According to the Corvette Museum the curb weight on a 2001 coupe (A4) is 3214 #, convertible (Z4) is 3210 # and z06 (M6) is 3115 #
I think you will see several different weights depending if its "Dry" or "Curb" or model year and tranny. But they all should be close to the ones above.
Old Jun 18, 2009 | 09:24 PM
JEEP/C5's Avatar
JEEP/C5
Oh, I didn't notice this but unless you replaced the engine with an "Iron Block" - you have an aluminum block "LS1"
Old Jun 18, 2009 | 10:25 PM
vettandtyphoon1
no i replaced it with an iron block
Old Jun 18, 2009 | 10:40 PM
MagRedConv's Avatar
MagRedConv
Try the Weights, measurements, etc. sticky here in Gen.
Old Jun 18, 2009 | 10:47 PM
Quickshift_C5's Avatar
Quickshift_C5
I weighed my 99 FRC with a full tank of gas and it was 3179lbs without me or anything else in it.
Old Jun 18, 2009 | 11:09 PM
itzza427's Avatar
itzza427
From this it would appear the FRC is a bit lighter than the Z06! Mine should be about the same as mine is a 2000 built late 99.
Old Jun 19, 2009 | 07:02 AM
Patman's Avatar
Patman
I believe the iron block adds about 70 lbs compared to an aluminum block, so you'd probably be looking at a curb weight of just under 3300 pounds for your car (on a full tank of gas).
Old Jun 19, 2009 | 07:15 AM
AU N EGL's Avatar
AU N EGL
advertised wts are a bit low.
coupe ~ 3450 lbs with 200 lbs of driver and some fuel
an iron block will ad close to 75 lbs, but more important move the wt distribution forward
so my need to ad 75lbs of ballast to the rear of the car for handling.
To how much does a c5 wiegh?
