Does everyone just use heavy duty 3m double sided tape? I am getting this done today and am wondering what the best way to mount is. My HID came with metal brackets and I have seen them mounted with the tape and brackets together....any info would be great! Thanks all.
I just put the tape on the ballast itself. Be sure to clean both surfaces well and you shouldn't have any problems
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
Either is fine. As long as you use good tape and prep the area you should have no problems. Make sure you mount it where the wires won't get caught up in the headlight operations. There is tons of space in the C5 for this.
From: "This is not a psychotic episode, but a cleansing moment of clarity."
Originally Posted by MSG C5
I've always wondered where the best location is to mount these ballasts? Any pics?
Here are a couple. I've got three sets of ballasts on both sides since this pic, which only shows two. Both of these are bolted down using the metal brackets.
Front of car to the left in first photo
Front of car at the top in the second photo
On my third set of ballasts, I was able to bolt it in on the driver side, but had no choice other than to use heavy duty double sided tape to adhere it to the other ballast on the passenger side due to the different configuration under there.
