TR55 is irridium and for long life I believe - good for a stock vette
TR6 is a copper electrode good for higher hp cars.
people have claimed to use both with good results in a stock vette. problem is the TR6 will wear out and needs to be changed pretty often. like every 15K I believe.
The TR55 and TR5 are the same; the 55 is gapped at .055, the 5 is gapped at around .038 I believe. The deal is you shouldn't make a 55 go down to .038.
Go with a TR6 for high compression and power.
NGK recommends you step down 1 step colder for every 100 hp you add.
TR55 is between a TR5 and a TR6 in heat range. Think of it as a TR5.5. TR5 would be stock replacement for your application.
NGK makes ACDelco plugs.
A TR55 is a copper style plug. TR55GP's are a platinum plug.
Copper plugs run cooler and reduce spark knock caused by the super hot platinum or iridium wire.
