[Z06] New Column Lock Problem
Old Jun 22, 2009 | 04:41 PM
kmcrawford56's Avatar
kmcrawford56
2nd Gear
Default New Column Lock Problem
2002 ZO6 with all factory (Fixs) done, drove the car home from dealer and the first time I tried to drive it guess what? (Steering Column Lock) so what do I do from here? I need Help?? I have a big yellow peice of chevy junk in my yard! Can't drive it!
Old Jun 22, 2009 | 05:18 PM
2K3Z06's Avatar
2K3Z06
From: KADS- If it has wings or an engine, I can break it. Dallas TX
Tow it to the ford dealer, and get a junk mustang................................
Old Jun 22, 2009 | 06:12 PM
vms4evr's Avatar
vms4evr
There is no such thing as a "NEW" Column Lock Problem. It's the same problem that GM never fixed to date. Go order a CLB from Corvettes of Houston and install it. Problem solved with a real engineering fix that works.
Old Jun 22, 2009 | 09:00 PM
RW Foster's Avatar
RW Foster
I took my 2004 Z06 to the dealer just today and told them I wanted the lock plate removed and they acted like they never heard of such a thing and kept trying to change the subject.
I told them I would PAY them to take it out. I just want it out.
Old Jun 23, 2009 | 12:45 AM
slwhite's Avatar
slwhite
It cannot be emphasized enough: none of the GM "fixes" for this problem have worked over the long term. Buy the aftermarket CLB unit from Corvettes of Houston, install it, and problem solved.
Old Jun 23, 2009 | 12:46 AM
slwhite's Avatar
slwhite
Removing the lock plate will not fix the problem.
Old Jun 23, 2009 | 03:01 PM
TAC's Avatar
TAC
Neither will getting the CofH column lock bypass completely fix things. I have one in and it is doing what it's supposed to do. However, since putting it in I have twice had the car stall immediately after starting and give me a Pull Key and wait 10 seconds error message. The steering wheel can be turned fully at this point so the locking mechanism is defeated, yet I still got stalled out. Luckily, both times after waiting the 10 seconds the car started right up and ran fine.
Old Jun 23, 2009 | 03:43 PM
pgj98m3's Avatar
pgj98m3
Ahhhhh...I was getting the pull key and wait and just assumed it was my sloppy key insertion. 3 weeks ago I took my 99FRC to the dealer with leaky butt syndrome and then the Column Lock tripped. I hope to get my car back today....then I'm installing the C of H fix
Old Jun 23, 2009 | 04:00 PM
phalanx256's Avatar
phalanx256
Yeah... I'm getting the SCL error as well after three(!) recall fixes. This time the actuator has gone bad, and the dealer wanted $500 to replace since the actuator is not a part of the recall's fix. No thanks. Going to Patrick Sparks instead...
Old Jun 23, 2009 | 04:21 PM
Tech's Avatar
Tech
FYI, even the instructions on the CoH CLB say that it does NOT fix cars that have an EXISTING "Service Column Lock" problem. I was shocked to read it.
Old Jun 23, 2009 | 04:31 PM
phalanx256's Avatar
phalanx256
No you're right it won't fix a standard SCL. In my case the actuator won't engage. I hope this won't have the "rabbit hole" effect.
Old Jun 23, 2009 | 05:52 PM
Drewstein's Avatar
Drewstein
Fixed my existing problem. Car was locked and stuck in the garage until that wonderful box arrived. It not only unlocked my column, but kept it from ever locking again.
Taking it to the dealer is just going to cause more problems FYI.
Old Jun 23, 2009 | 07:48 PM
slwhite's Avatar
slwhite
You are the first person I have ever heard of that has had a problem with the COH CLB device. Maybe I missed some. Mine has been installed for 5 years and no problem. Has anyone else ever had a problem with the COH CLB device?
Old Jun 23, 2009 | 07:51 PM
slwhite's Avatar
slwhite
The reason is that the actuator is bad. When you install the COH CLB in a car with a functioning column lock (good actuator), the actuator is then permanently bypassed and thus it can never become defective after that.
Old Jun 24, 2009 | 09:13 AM
vsellens's Avatar
vsellens
I get at least 2 calls a day with this same question. It is either instalation error or, If the driver "or transister" in the BCM for the column lock is already damaged or weaked from the million plus times it has been used every time you start your car the clb will not fix it. It is a preventative. The clb does not replace the driver. If the integrity of the BCM is good you will not have a problem.
Old Jun 24, 2009 | 09:18 AM
Tech's Avatar
Tech
FYI, I didn't say it didn't fix _my_ problem.
I got the SCL message and ordered the CLB. By the time the CLB showed up, the SCL message was gone and the car was acting fine. I went ahead and installed the CLB for safe measure.
Old Jun 24, 2009 | 01:50 PM
RW Foster's Avatar
RW Foster
Why does removing the lock plate not fix the problem?
To New Column Lock Problem
Old Jun 24, 2009 | 01:58 PM
Drewstein's Avatar
Drewstein
If the locking pin is extended it will enable the fuel cutoff at 1.5mph. So your wheel will turn but you can't go faster than that so have fun.
CLB /Thread
Old Jun 24, 2009 | 11:55 PM
slwhite's Avatar
slwhite
Because the source of most of the problems is that the actuator, which is a type of motor, has gone bad. The computer can sense the current draw of the actuator and if it is not the proper amount, it can be fooled into thinking that the actuator is in an improper position such as being engaged into the locking plate, even if it is not. So, even if the locking plate is gone, if the computer thinks the actuator is engaged into the locking plate, it will cut off your engine. That is why the COH CLB disables the circuit to the actuator. It replaces that circuit with its own which simulates the load of a functional actuator.
Old Jun 26, 2009 | 01:13 AM
ScootNoot's Avatar
ScootNoot
7th Gear
I have a new bypass kit that was never installed on my car if somebody wants it. I'll give ya a good deal, I don't even think i've opened the package.
