Question / Motive Power Bleeder
Old Jun 23, 2009 | 09:10 AM
Golf Man's Avatar
Golf Man
Default Question / Motive Power Bleeder
I'm looking at purchasing a Motive Power Bleeder. I was wondering if anyone is using the universal mount version? (model #0101) Any feedback would be appreciated.
Old Jun 23, 2009 | 05:44 PM
Last C5's Avatar
Last C5
NO!!!! At least I hope not. That thing does work, but it takes forever to put it on and take it off. Get the GM adapter and you'll be a lot happier.
Old Jun 23, 2009 | 05:57 PM
4440stevesvette's Avatar
4440stevesvette
I use the Motive Power Bleeder and it works beautifully. I don't know what the universal fit model is but I would recommend getting a year and model specfic unit.
Old Jun 23, 2009 | 05:58 PM
AU N EGL's Avatar
AU N EGL
Old Jun 23, 2009 | 07:18 PM
cookrent's Avatar
cookrent
St. Jude Donor '08
That's what came with mine and that was what I used. It did not work on my son's VW and had to buy that one. If you can buy it with the GM one I would. It does work with universal one.
Old Jun 23, 2009 | 08:41 PM
Patches's Avatar
Patches
I have both the universal, which I bought before the GM was available, and I have the GM unit as well. The GM cap does not fit tightly enough for my comfort. The universal takes longer to secure but works much better for me. I pump the bleeder up to 20-25 psi and have had the GM cap pop off at that pressure. The GM brake line system is bled at 25-30 psi when the automated bleeding procedure is performed with a Tech II so the pressure I use is safe.
Old Jun 23, 2009 | 09:24 PM
dndrsn's Avatar
dndrsn
Old Jun 23, 2009 | 09:37 PM
4DRUSH's Avatar
4DRUSH
I personally found the power bleeder to be junk and threw it in the trash. Too much BS, I'd rather use the brake pedal.
Old Jun 23, 2009 | 10:22 PM
dndrsn's Avatar
dndrsn
I use the power bleeder because my arms are not long enough to reach the bleed screws while I am inside the car pushing the brake pedal.
Old Jun 24, 2009 | 09:29 AM
Golf Man's Avatar
Golf Man
Thanks for all the feedback...with a tacoma and altima also parked in the stable, I was hoping for a one-size fits all approach.
To Question / Motive Power Bleeder
