Power Seat Switches?
Old Jun 25, 2009 | 01:22 AM
83Camaro's Avatar
83Camaro
Default Power Seat Switches?
I only ever used the long adjuster on the seat to move the seat foward or back, recently i discovered none of the other smaller switches on the seat work, at all, looking for advice on what to check the seat i assume those are to control the lumbar support, like i said none of them work, but the front to back adjuster the longer bigger rectangle switch works.
Old Jun 25, 2009 | 11:06 AM
Texas Dave's Avatar
Texas Dave
My passenger's side acted like this when I bought the car. Turns out there was a leak on the right window that dripped right on to the switch and killed those buttons. Had to replace the whole module, thankfully the place I bought it from paid for it. Was $125 or so for the module.
Old Jun 25, 2009 | 11:48 PM
83Camaro's Avatar
83Camaro
thanks, any other input?
Old Jun 26, 2009 | 02:09 AM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
Can you hear the air pump running when you try to inflate the lumbar or bolsters?
Old Jun 26, 2009 | 04:43 AM
Jistari's Avatar
Jistari
If you get the sound when you press it (you would have to do it from outside, with your head down by the seat, its a quiet noise), then the baldders are gone.
You can get bladders from GM or some people have had good experience with using Obese Blood Pressure Cuffs (B/P cuff for fat people). They are cheap, and with very little work slip right in and works as well as the originals.
If you dont get the sound, the seat comes out with foru bolts, the plug may not be connected all the way?
Old Jun 26, 2009 | 11:15 AM
83Camaro's Avatar
83Camaro
I dont hear anything running, nothing happens at all with those switches. Ill double check again but i dont hear anything when i press them, are those switches on a different plug in perhaps? cause the front and back works just none of the lumbar adjustments.
Old Jun 29, 2009 | 10:09 PM
83Camaro's Avatar
83Camaro
anyone else?
Old Jun 30, 2009 | 01:19 AM
DeeGee's Avatar
DeeGee
I'd say it could be one of three things all of which are common problems
I'd start with the connector. Pull the connector and check the circuits with a multi meter. Select each function in turn and see if you have a voltage. If not, its an issue with the motors. If you do, then I'd turn to the bladders. There are a number of 90 degree pipe connectors in the system. They become brittle with age and can break allowing air to escape. New connectors should fix it. It's unusual for the bladders themselves to spring a leak. You can get to the bladders without taking the seat out. Unzip the covers around the seat back and it should give enough access to check.
Failing that as Texas Dave suggests it may be a switch issue. They are notoriously unreliable and many have drained batteries due to bad switches.
Have to say that if the seat is motoring but the other functions are bad I'd be thinking bladders.
Here's the connector info:
Connector Part Information
* 12160773
* 26-Way F (NAT)
Pin
Wire Color
Circuit No.
Function
1
DK BLU
1520
Power Seat Switch Signal-Front Down
2
Not Used
3
YEL
1519
Power Seat Switch Signal-Rear Up
4
Not Used
5
GRY
764
Relay Coil Feed-Upper Lumbar Deflate (Telescopic and Memory)
6
Not Used
7
GRY/BLK
1798
Power Seat Switch Return
8
Not Used
9
GRY/BLK
466
Relay Coil Feed-Side Bolster Deflate (Telescopic and Memory)
10
Not Used
11
PNK
789
Relay Coil Feed-Lower Lumbar Inflate (Telescopic and Memory)
12
Not Used
13
BRN
617
Power Seat Switch Signal-Horizontal Aft
14
GRY
613
Power Seat Switch Signal-Horizontal Forward
15
Not Used
16
YEL
777
Relay Coil Feed-Upper Lumbar Inflate (Telescopic and Memory)
17
Not Used
18
PPL
765
Relay Coil Feed-Side Bolster Inflate (Telescopic and Memory)
19
Not Used
20
ORN
1740
Battery Fused Feed (Telescopic and Memory)
21
Not Used
22
YEL
386
23
Not Used
24
LT BLU
1521
Power Seat Switch Signal-Rear Down
25
Not Used
26
DK GRN
1518
Power Seat Switch Signal-Front Up
Old Jun 30, 2009 | 11:22 AM
83Camaro's Avatar
83Camaro
thank you, ill have to take the seat out and check it out this weekend.
Old Jun 30, 2009 | 01:21 PM
ecoman's Avatar
ecoman
Had the same issue with mine replaced the switch and all worked great.Found 1 on fleabay.
Old Jul 1, 2009 | 01:08 AM
83Camaro's Avatar
83Camaro
the entire switch or what did you replace exactly?
Old Jul 1, 2009 | 01:26 AM
DeeGee's Avatar
DeeGee
The switch is a single unit:
Seat Switch Replacement - Power
Removal Procedure
1. Remove the seat back recliner handle.
1. With a suitable blunt ended tool inserted between the cushion and the handle push the handle retaining spring clip down.
2. Pull the handle from the shaft.
2. Remove the screws attaching the seat side trim panel.
3. Rock the panel side to side working the barrel post clip (1) out of the seat frame.
4. Reposition panel away from the seat.
5. Disconnect the switch harness.
6. Remove the switch.
Installation Procedure
1. Install the switch to the side trim panel.
2. Install a new barrel clip (1) to the trim panel upper barrel post (2).
3. Connect the switch harness.
4. Install the seat side trim panel.
* Push the barrel post with clip through the hole in the seat cover and into the seat frame.
* Install the front and rear trim panel attaching screws.
5. Install the seat back recliner handle.
1. Position the handle retaining spring clip into the lock position.
2. Snap the handle onto the reclining mechanism shaft.
Old Sep 30, 2009 | 08:49 AM
magillicuttyjones's Avatar
magillicuttyjones
After leaving my car outside for two days in the rain I am now faced with this switch replacement procedure. (coincidence... i think not) Yaay for me. It seems fairly straight forward then again I'm not very adept at fixing cars. Anyone run into problems replacing the switch?
Old Sep 30, 2009 | 09:40 AM
magillicuttyjones
Question about step 2 of install - you need to replace the barrel clip? Anyone have a part number, are these easy to find online?
Removal Procedure
To Power Seat Switches?
