I went to change lanes tonight and my turn signal indicator did not work. I tried both ways a couple of times and nothing happened. I did not pull the car over and check if the exterior signal lights were working. this has happened one other time and I actually don't remember what I did to get the indicators to work last time. tonight, I just turned the car off and back on while rolling to a light. situation was solved but obviously there is a problem to be solved here.
Definitely install Richards bi-pass cable. I installed one 2 years ago and it's one of the best mods I've done to my 2000 vert. It costs about $60 and takes 15-20 minutes and you'll never have turn signal issues again. Replacing the hazard switch is just asking to do it again when the second one fails. I have no financial or business relationship with Corvette-enhancements, I'm simply a very satisfied customer that believes in passing along mods that make our cars better!
I went with the bypass because I also have led taillights which the bypass fixes those issues too. It took 10 mins for me to install and much easier than digging out / replacing the stock. I only installed it a month ago but no more turn signal issues.
Get the bypass, easier to install and you'll also need i if/when you get some LEDs. Since I installed them, my turn signal issues went bye bye!
QUESTION: Does this bypass kit just remove the turn signal operation from going through the Hazard 4 way flashers, but leave the Hazard 4 way flashers functional if you need it, or does it just eliminate the Hazard altogether leaving you with ONLY more reliable turn signals????
Thanks, Jennifer
Thanks, Jennifer
Hazards will still function with flasher bypass installed
I'm not trying to hi-jack this thread...but I too am having this problem, but only on the right side. My lights still works on the outside...just doesn't flash on the inside. Is this a problem the bypass will fix or do I have a different problem. I'm looking at getting some switchbacks and will need the bypass anyway.
