Bottom scoop replacement.
Old Jun 27, 2009 | 03:21 PM
bluerose's Avatar
bluerose
Default Bottom scoop replacement.
(OK fixed my technical term)
The Air Dam under the front end of the 2003 I just bought has been ripped off.
My Mechanic says it is common....but it needs to be there. Before I give the dealer a rash of crap....Is the mechanic accurate and how much am I looking at to put it back on myself?
-- Taking it back to the dealer because the front brakes are below 50% and it's illegal for them to sell it that way....so they will be replacing those. --
Old Jun 27, 2009 | 03:52 PM
bluerose's Avatar
bluerose
Too...reply to my own post.
It seems to be decently cheap and fairly easy. Not something you want to spend money on every few weeks but not bad....
So ignore my post
Old Jun 27, 2009 | 04:00 PM
NorCalVette Kid's Avatar
NorCalVette Kid
St. Jude Donor '09
Yeah it does need it. It helps direct air flow to your radiator. You might want to check to see if your skid plate isn't damaged as well. If your spoiler is missing it could mean that the previous owner hit something. JMO
Old Jun 27, 2009 | 04:05 PM
Fratbragen's Avatar
Fratbragen
yeah, I'd say most would agree that you need the air dam, but it is a huge pain. I've heard of guys removing it and the car not overheating, but I'd never take it off. These things breathe from the bottom, so it's important as much air crosses the radiator as possible.
In my most humble opinion, this is one of the biggest pains about the C5.
bluerose's Avatar
bluerose
Will look at that too...thanks for the info.
Old Jun 27, 2009 | 04:10 PM
NorCalVette Kid
St. Jude Donor '09
That's what happened to me, mine was missing and I noticed my skid was bent. I bought a new skid and 3pc air dam. I just gotta get my lazy butt to fix it.
Old Jun 27, 2009 | 04:16 PM
bluerose's Avatar
bluerose
Supposed to be in the 100's down here quick so I'll see if the dealer I bought it from will put one on for free since they have to to fix the brakes.....or at least at a buy the part and they install free kinda thing.
If not I'll order one and do it myself (or with Hubby's help) I'm not totally useless with a wrench
Old Jun 27, 2009 | 04:26 PM
NorCalVette Kid
St. Jude Donor '09
It's gonna be hot up here as well!!
The dealer should do it for free! Be firm with them. I'm sure the Hubby will do it for some beer and pizza.
Old Jun 27, 2009 | 04:37 PM
sneakelman's Avatar
sneakelman
St. Jude Donor '08-'09
It literally takes about 5 minutes to replace the center spring loaded section.(once you have the car up on stands) Four 10mm bolts, one on each side, and two for the aluminum braces that hold the middle taught.
As for the side pieces....only takes a couple minutes to bolt them up as well. Once the car is in the air, should take you about 15 minutes max.
And yes, you DO need that to direct airflow to the radiator. It's a simple job, so start wrenching.
Old Jun 27, 2009 | 05:37 PM
bluerose's Avatar
bluerose
Ok picked the car up and only the center piece is missing...
Skid plate looks well used but not broken or bent.
Old Jun 27, 2009 | 05:45 PM
NorCalVette Kid
St. Jude Donor '09
Great! Mid America has them for 70 bucks. Here's a link: http://www.mamotorworks.com
Old Jun 27, 2009 | 06:26 PM
And check with Gene at gmpartshouse.com for good pricing.
Old Jun 27, 2009 | 07:41 PM
dobewillie's Avatar
dobewillie
dam never fixed anything in ten minutes and always cut myself good luck
Old Jun 27, 2009 | 09:42 PM
robsc501's Avatar
robsc501
Hi There;
sneakleman. Easy to replace.
robsc501
Old Jun 27, 2009 | 10:24 PM
DevilMan02's Avatar
DevilMan02
how the hell did it "just get ripped off"
I've had my 2002 for a couple years now and I've driven 160 mph, driven over speed bumps, gone over rough roads, driven on gravel, etc. And that **** is still hanging on.
I have no idea what you drove over, but if it's a dealer/installation issue, you need to have THEM replace it.
Old Jun 28, 2009 | 01:57 AM
bluerose's Avatar
bluerose
Don't know I have only had the car a bit over 24 hours...took it to the mechanic for a going over and he told me it was gone. It's my first vette I have no clue...thus the mechanic...
Have an appointment with dealer on Tuesday for the brakes and they will tell me if they are going to do anything....Car was bought "As Is"...brakes are safety and must be replaced but this might just be my problem....
Not worried really but would like them to do it.
Old Jun 28, 2009 | 02:31 AM
DeeGee's Avatar
DeeGee
As the guys say, it's easy to fix
Heres a How To if you plan to do it yourself:
Air Deflector Replacement - Front Bumper Fascia
Removal Procedure
1. Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
2. Remove the center air deflector bolts.
3. Remove the air deflector from the vehicle.
Installation Procedure
1. Position the center air deflector between the side valances.
Notice
Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
2. Install the center air deflector and attaching bolts.
Tighten
Tighten the air deflector bolts to 7 N•m (62 lb in).
3. Lower the vehicle.
To Bottom scoop replacement.
Old Jun 28, 2009 | 11:10 AM
Bill Dearborn's Avatar
Bill Dearborn
Not a big deal. They are easily replaced. They are important to the performance of the car including coolant temp, highway gas mileage and high speed running. The spoilers are part of the reason GM got such low aero drag numbers on the car. When the C5 was introduced in 97 (12 years ago) the only car with a better number was the Saturn EV1 which was just marginally better.
So the spoilers are not much of a pain to the people who realize why they are there.
Bill
Old Sep 5, 2009 | 04:52 PM
IRON MAIDEN's Avatar
IRON MAIDEN
Removal Procedure
Notice
Tighten
Thought the center section was spring loaded? Does it lookm like I'm missing anything or can I just get the center section and bolt it up
Old Sep 5, 2009 | 05:39 PM
PewtVette's Avatar
PewtVette
You'll bolt right up man (you have the aluminum brackets in the middle). The spring loading mechanism is part of the plastic air deflector that you will be replacing.
I replaced mine last year after running over a critter in the middle of the HWY. He bent the **** out of my deflector (the spring loaded mechanism part).
