Steering wheel squeals!!!
Old Aug 11, 2009 | 06:45 PM
wdtiger's Avatar
wdtiger
Same problem on my Y2k FRC.
Old Aug 11, 2009 | 06:56 PM
SilentFright's Avatar
SilentFright
From: Arlington Texas, originally from San Angelo, TX
Same annoying a fu(k squeel here as well. It sounds like my steering wheel is farting on me.
Old May 18, 2010 | 11:43 AM
Milan's Avatar
Milan
Did anyone ever figure this out? I have the same problem too....sooo annoying
Old Jun 27, 2010 | 12:08 PM
mosimann's Avatar
mosimann
No updates on this yet?
Old Mar 16, 2013 | 07:11 PM
tbar1963's Avatar
tbar1963
St. Jude Donor '08
Just started on my 02 Vert...very annoying...no new updates or pics????how to....
Old Mar 17, 2013 | 05:27 PM
YLO Z06's Avatar
YLO Z06
2023 C5 of the Year Finalist - Modified
I have had some luck spraying WD40 on the steering column universal joint that is directly beneath the brake booster in the engine compartment. Easy to see if you lean over the brake booster and look below it, close to the firewall. It is a silver U-joint on the steering column. It is a real b*tch to get to from above, but luckily the WD40 sprays pretty far. I can get a small can of WD40 beneath the brake booster somewhat and then let it fly, soaking the U-joint. The noise will go away, but will return after a few days. I would rather spray it white lithium grease, but that does not travel nearly as far as the WD40, so my attempts have failed thus far. I am confident that U-joint is the culprit, as the noise completely disappears when I douse it with WD40, but it needs some heavier lubricant to really soak in and be a more permanent solution. I will keep trying to get at it. Maybe better access from underneath the car?
Old Jan 7, 2022 | 04:32 PM
Vetterator's Avatar
Vetterator
Default Steering wheel
Try david at vqcarbon. Made in the usa and great work. Good luck
Old Jan 7, 2022 | 08:10 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
Did you realize that you posted to a 9 year old thread(last posted on 3/7/2013) ?03-
Old Jan 9, 2022 | 04:10 PM
Closing this one.
