Steering wheel squeals!!!
Old Jul 4, 2009 | 04:34 PM
03 Z-oh-6's Avatar
03 Z-oh-6
Default Steering wheel squeals!!!
It's really annoying! How can I fix this?
Old Jul 4, 2009 | 04:37 PM
Munch's Avatar
Munch
St. Jude Donor '10
Are you sure you're not just going too fast and it's actually the tires squealing when you turn the wheel?
Old Jul 5, 2009 | 07:54 PM
clif's Avatar
clif
St. Jude Donor '09-'10
My steering column also squeaks. Its very annoying...
Old Jul 5, 2009 | 08:05 PM
SkyWarp's Avatar
SkyWarp
Old Jul 5, 2009 | 08:31 PM
209TIME!!!'s Avatar
209TIME!!!
I have that problem also
Old Jul 5, 2009 | 08:57 PM
CLEAR's Avatar
CLEAR
me too.
Old Jul 5, 2009 | 09:05 PM
RogerZ06's Avatar
RogerZ06
Mine squeaks when I'm going really slow. I think its the steering wheel sensor for the active handling that's going bad.
Old Jul 5, 2009 | 09:41 PM
TEXHAWK0's Avatar
TEXHAWK0
There is a post somewhere with pictures on where the grease the steering shaft to fix this. It is in front of the firewall, not inside the car.
Old Jul 6, 2009 | 01:38 AM
DeeGee's Avatar
DeeGee
The post is on Tech Tips but I cant access it any more
It involves lubricating the joint on the steering column. To get at it you need to pull the 4 screws on the drivers kick panel
Old Jul 6, 2009 | 05:31 AM
clif's Avatar
clif
I have seen this picture many times. I would rather see a detailed step-by-step write up. Hopefully, someone has fixed theirs by now!
Old Jul 6, 2009 | 11:54 AM
Ryan040675's Avatar
Ryan040675
Old Jul 6, 2009 | 12:05 PM
SkyWarp's Avatar
SkyWarp
Old Jul 7, 2009 | 08:50 AM
SkyWarp's Avatar
SkyWarp
Old Jul 7, 2009 | 10:04 AM
Texas Dave's Avatar
Texas Dave
That picture is kind of useless by itself.
Old Jul 7, 2009 | 10:18 AM
jovette's Avatar
jovette
I couldn't agree more! I too have seen the picture and post many times, and I too have the squeaky steering wheel issue. I went so far as to purchase the spray can of white lithium grease, I just need a better idea of where, and how it should be applied!!!
So, what do you say forum members, does anyone out there have better instructions on how to get this job done?
Old Jul 7, 2009 | 02:51 PM
philadd's Avatar
philadd
I'd like to know as well. My squeeking steering wheel is getting annoying, and I have no idea where or what to lubricate.
Old Jul 7, 2009 | 03:07 PM
DeeGee's Avatar
DeeGee
Sorry guys this is the one from the Tech Tip
Mine doesn't squeak
Best I can do and I've not seen anything better for the last 5 years
Document ID# 798048
2002 Chevrolet Corvette
Noise in Steering Column
Step
Action
Yes
No
1
Did you review the Steering Wheel and Column Description and perform the necessary inspections?
Go to Step 2
Go to Symptoms - Steering Wheel and Column
2
Verify that noise is present in the steering column during operation.
Is noise present in the steering column during operation?
Go to Step 3
System OK
3
Inspect the steering column components for looseness.
Is the steering column components loose?
Go to Step 10
Go to Step 4
4
Inspect the SIR/SRS coil for noise.
Is the SIR/SRS coil noisy?
Go to Step 11
Go to Step 5
5
Inspect the horn contact ring for lubrication.
Is the horn contact ring lubricated?
Go to Step 12
Go to Step 6
6
Inspect the lock plate retaining ring for the correct installation.
Is the lock plate retaining ring installed properly?
Go to Step 13
Go to Step 7
7
Inspect the shaft bearing for the following conditions:
* Damage
* Lubrication
* Wear
* Proper seating
Are the bearings in need of repair or replacement?
Go to Step 14
Go to Step 8
8
Inspect the spherical joint for lubrication.
Is the spherical joint lubricated?
Go to Step 15
Go to Step 9
9
Inspect the steering column coupling for looseness.
Is the steering column coupling loose?
Go to Step 16
Go to Step 3
10
Tighten the steering column components to specifications. Refer to Fastener Tightening Specifications .
Did you complete the repair?
Go to Step 17
11
Replace the SIR coil. Refer to Inflatable Restraint Steering Wheel Module Coil Replacement in SIR.
Go to Step 17
12
Lubricate the horn contact ring.
Go to Step 17
13
Install the lock plate retaining ring properly.
Go to Step 17
14
Repair the shaft bearings as necessary. Refer to Steering Shaft, Lower Bearing, and Jacket - Disassemble - Off Vehicle .
Go to Step 17
15
Lubricate the spherical joints.
Go to Step 17
16
Tighten the steering column coupling to specifications. Refer to Fastener Tightening Specifications .
Go to Step 17
17
Operate the system in order to verify the repair.
Did you correct the condition?
System OK
Go to Step 3
Document ID# 798048
To Steering wheel squeals!!!
Old Jul 7, 2009 | 03:17 PM
ieatyllwcryns's Avatar
ieatyllwcryns
same problem here
Old Jul 7, 2009 | 03:49 PM
jedblanks's Avatar
jedblanks
Same problem on a 97, so you can rule out active handling sensor.
It sounds like plastic on plastic and it sounds like it's in the actually steering wheel, not down near the floor pan (tried greasing like picture but no dice).
Old Jul 8, 2009 | 12:44 AM
mosimann's Avatar
mosimann
One more.
