Wheel Offset question
Old Jul 4, 2009 | 07:46 PM
devilchrono's Avatar
devilchrono
Default Wheel Offset question
So, I'm looking into getting some new wheels eventually, and was wanting to know if c6 wheels will fit on the c5's? I've found a few that I like, but they seem to only come in for the c6's at this time.
TIA ,
Justin
Old Jul 5, 2009 | 09:44 AM
wfdlt8's Avatar
wfdlt8
I have the c6 wheels from a 2005. I had to use one quarter inch spacers on rears, the fronts worked fine.
Old Jul 5, 2009 | 09:51 AM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
We have a few C6 style wheels that are made to fit the C5 with correct offsets. Check them out:
http://www.shop.jwmotoring.com/categ...?categoryId=19
Old Jul 5, 2009 | 02:54 PM
Jims2001's Avatar
Jims2001
Do you have the C6 style in chrome 18/19 or 19/20?
Old Jul 5, 2009 | 07:05 PM
Indy's Avatar
Indy
C6 style for the C5 are ok.
C6 wheels need spacers.
C6 Z06 wheels will need fender flares.
Old Jul 5, 2009 | 08:54 PM
devilchrono
These are the wheels I'm wanting to get, in the c6 18x9.5/19x10 sizes.
http://www.westcoastcorvette.com/p-2...-c6-c6z06.aspx
Are you saying that I'll need fender flares as well as spacers, or would I be ok with just the spacers, since they have the normal c6 offset/backspace?
Old Jul 6, 2009 | 01:23 PM
devilchrono
Old Jul 6, 2009 | 01:56 PM
Nd4spd2's Avatar
Nd4spd2
St. Jude Donor '08
I just picked up a 2000 hardtop last week that came with silver painted wheels. I had the stock 08 gumby wheels off of my 08 after converting to a widebody so I stuck them on over the weekend. I didn't need to use any spacers for clearance issues but the rears do sit inboard about a 1/4" further than the stock ones did. I'm trying to decide whether it's worth getting spacers and longer studs just to move them out 1/4".
Stock wheels
08 wheels
Old Jul 7, 2009 | 08:40 AM
devilchrono
Old Jul 9, 2009 | 11:13 AM
devilchrono
Old Jul 10, 2009 | 08:34 AM
AustinVetteFan's Avatar
AustinVetteFan
Here's one of the best wheel size/offset calculators I've found so far:
http://www.rims-n-tires.com/rt_specs.jsp
Put in the size of your stock wheel and the wheel you're considering and it will give you a side-by-side comparison, with illustrations, of the differences. Plus it will describe how the changes will affect the clearances with the suspension, fender, and wheelwell. It should give you a good idea of how the C6 wheels will fit on the C5.
Old Jul 15, 2009 | 03:12 AM
19torch99's Avatar
19torch99
OEM C6 wheels with a 1" adapter:
Old Jul 15, 2009 | 06:25 AM
3GenVettes's Avatar
3GenVettes
Do you realize that the specific sizes named above mix the C6 ZO6 front tire size with the C6 base rear tire size? Those sizes would not 'require' flares, for the front or rear. However, the front would set a little outboard of wheel arch lip and the rears would set a little inboard of the rear wheel arch lip. Also, you would have to be very careful with tire size selection. If you tried to up your rear rubber width you would have problem with the tire rubbing on the inner side of the wheel well without a spacer. If you stayed with OEM width for base C6 tire size you can normally get by without a spacer.
Caution, the WCC wheel reference does not make specific reference to the offsets unless I missed that piece of information. Rim width and diameters are not enough info to really know the fitment without also knowing the offsets. The above statement were based on stock C6 offsets when applied to a C5.
Old Jul 15, 2009 | 08:39 AM
Nd4spd2's Avatar
Nd4spd2
St. Jude Donor '08
19torch99, how does that look up close as far as the wheel being spaced away from the calipers? Can you post a pic of that? Where did you get your spacers? thanks
Old Jul 15, 2009 | 08:53 AM
Nd4spd2's Avatar
Nd4spd2
St. Jude Donor '08
The C6 stock rear wheel offset is 79mm. This doesn't go that high and it won't allow you to enter your own numbers. You have to pick from the drop down list. Am I missing something?
Old Jul 15, 2009 | 08:59 AM
New Jersey's Avatar
New Jersey
hit ebay up for the spacers. i bought mine for $60 and theyre very well made. 1" bolt on makes them sit our about the EXACT same amount as the stock c5 wheel. and this way u dont have to mess with stupid long studs and slip ons. fronts ARE the same amount out.
Old Jul 15, 2009 | 09:01 AM
New Jersey's Avatar
New Jersey
To Wheel Offset question
Old Jul 16, 2009 | 02:11 AM
AustinVetteFan
Hmmm...no, you're not missing a thing. Although I've played around with that calculator quite a bit, I'd never tried the C6 sizes before and hadn't noticed that the max offset of the calculator was 65. Sorry about that. But, if you were to put in the stock wheels on the left, and the C6 wheels on the right, using the 65mm offset, the results below should still be reasonably valid. Just remember that the wheels will actually be 14mm (slightly more than 1/2 inch) further outboard than indicated in the clearance section. Perfect? No, but still useful.
Old Jul 16, 2009 | 09:22 AM
Eric the Ricer's Avatar
Eric the Ricer
From: Beyonce > Taylor Swift - Welcome to the good life!
St. Jude Donor '07
Originally Posted by New Jersey
You really need some hub centric spacers man, especially that big.
Old Jul 17, 2009 | 09:25 AM
New Jersey's Avatar
New Jersey
why?
the face of my brake rotors are not hubcentric
people always say that without knowing what theyre talking about
