blinker problem
Old Jul 5, 2009 | 12:49 AM
Z06streetracer's Avatar
Z06streetracer
Default blinker problem
my blinkers dont work all the time does anybody have any ideas
dont want to pay 100 deductable from my warranty
Old Jul 5, 2009 | 11:53 AM
Z06streetracer
top
Old Jul 5, 2009 | 12:16 PM
(Lucy)'s Avatar
(Lucy)
Account disabled by request Dec 2015
There is a by pass you can purchase to alleviate this problem!! The other options are 1. give it a tap on top of the dash 2. cycle the hazards a few times. The problem is that the contacts stick after they haven't been used in awhile. Even if you put a new switch in, sooner or later the same problem will occur.
Old Jul 5, 2009 | 08:57 PM
stevedun's Avatar
stevedun
Cruise-In 8-9-10-12 Veteran
Is it on? Then off? Then on? Then off?
Old Jul 6, 2009 | 12:35 AM
kyhotrod's Avatar
kyhotrod
I'd check the blinker fluid. Might be low.
Old Jul 6, 2009 | 12:39 AM
And7Baller's Avatar
And7Baller
I ordered the Flasher Fix from Corvette Enhancements. Hopefully it works.
Old Jul 6, 2009 | 12:54 AM
DeeGee's Avatar
DeeGee
It's probably one of the switches, either the hazard switch or the turn signal switch that has gone bad. Both are notoriously unreliable but both cost quite a few $ and are not easy to fix. Changing either will involve a strip down.
If you have a warranty paying the deductable will be about the cheapest and certainly the easiest way to fix it IMHO.
Old Jul 6, 2009 | 02:20 AM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
I had a buddy who had this problem, paid the stealership a great deal of money and still had issues. Ordered the part mentioned above from CORVETTE ENHANCEMENTS and I installed it in about 10 minutes and everything worked great. Still hasn't had any issues for over a 10 months now.
My new ride I will be picking up this week has the same problem and I have already ordered the part from them to fix it.
Micah
Old Jul 6, 2009 | 09:13 AM
Independent1's Avatar
Independent1
St. Jude Donor '08
^^I agree. Had this problem on my car. Lot of work to fix.
Old Jul 7, 2009 | 09:05 PM
Z06streetracer
thanks alot guys checking out corvette enhancements
Old Jul 9, 2009 | 09:07 AM
RSchleder's Avatar
RSchleder
I installed corvette-enhancements bi-pass cable 2 years ago. I strongly recommend it. Easy to install, very reliable and once it's installed, your turn signal issues are gone forever!!! Ron
Old Jul 9, 2009 | 01:25 PM
04 commemorative's Avatar
04 commemorative
St. Jude Donor '17
Wow have not heard them called "blinkers" in years !!!!!! Just how old are you?..
Old Jul 10, 2009 | 09:30 AM
ALEXAMES's Avatar
ALEXAMES
I call them blinkers and am 34. Maybe it's just you.
Old Jul 10, 2009 | 12:49 PM
Blown427conv's Avatar
Blown427conv
I just did the flasher bypass MOD I found on the Tech side last night. My flashers work 100% of the time now!!! I spent $12 and 15 mins. Search for it. I did the one where you cut 1 wire and splice an electronic $8 flasher in and jump power from another wire, all by your knee under the column. Easy and cheap.
To blinker problem
