How does heat exit engine bay?
Old Aug 27, 2018 | 10:48 AM
jjc508520's Avatar
jjc508520
I prop my hood open about 3in after a hot run - no sense in letting all the rubber and plastic bake. Just enough to not have the underhood light stay on...
Old Aug 27, 2018 | 11:19 AM
Tsumi's Avatar
Tsumi
As an FYI, cutting the rear hood seals might lower temperatures at low speed, but would introduce air under the hood at higher speeds (I believe about 30+ mph) because the base of the windshield is a high pressure zone. Air underneath the hood means more lift and drag. There is a reason cowl induction hoods are named induction, because they bring in air from the base of the windshield.
Old Aug 28, 2018 | 09:05 AM
Johnny the Greek's Avatar
Johnny the Greek
Default Heat under the hood
I do this too but I would like something more permanent....
Old Aug 28, 2018 | 09:14 AM
Johnny the Greek
I have been contemplating this now for several days. Under highway speeds the the openings in the seals will draw air into the engine compartment so therefore I do not believe there will be a hood lift.. I had a scoop on my old pickup truck with the opening in the back and if there was a leaf near that opening, the air would suck the leaf into the the engine... There is just too much air follow under the car. The opening(s) will provide more air flow into the engine area and also vent when is parked. The question is where the openings would be more effective and safe just in case I get rain on. Just my thoughts
Old Aug 28, 2018 | 10:30 AM
Tsumi's Avatar
Tsumi
You're thinking of it backwards. The hood does not have negative pressure. The base of the windshield has very high pressure. Hood vents relieve under hood pressure by allowing air to escape out the low pressure zone at the front of the hood. As air moves towards the back of the hood, pressure increases until the base of the windshield, where it is at its highest, and is higher than under hood pressure.
Old Aug 29, 2018 | 01:06 PM
The Rabbi's Avatar
The Rabbi
2018 C5 of Year Finalist
St. Jude Donor '14,'18
Don't latch the hood down.
This reminds me back in the early '80s outside of Chicago I had a rv trailer parked at a campground with a lake. On the weekends the city folk would come for the day and immediately opened their hoods. Never knew why.
Old Aug 29, 2018 | 03:31 PM
stief's Avatar
stief
C5 of Year Finalist (stock) 2019
underneath the car, up through the floorboards.......
Old Aug 29, 2018 | 07:50 PM
Johnny the Greek
Not overheat problem, just nowhere the heat to go when you are not moving!
Old Aug 29, 2018 | 07:58 PM
Tsumi's Avatar
Tsumi
The only permanent solution that doesn't negatively affect driving dynamics is hood vents towards the front of the hood, ideally right behind the radiator.
Old Aug 29, 2018 | 08:28 PM
Johnny the Greek
With my cold air ram overheating is not an issue. The issue is that heat is retained in the engine area when the corvette is parked, even in my garage. The hottest place under the hood is around the engine near the headers and heads and it bakes the hood and everything around it....
Old Aug 29, 2018 | 08:31 PM
Tsumi's Avatar
Tsumi
The hoods with three vents have vents for the headers. The Track-spec kit also comes with three vents, two at the side for the headers. However, if that is your only issue, just pop your hood open when you park it if you're so concerned about it. I wouldn't worry about it.
