[Z06] Odd, "Charge Fault" error message
Old Jul 6, 2009 | 02:06 PM
Warped Sol's Avatar
Warped Sol
Default Odd, "Charge Fault" error message
This has happened twice on starting. I get a very quick "Charge Fault blah blah" message, but it goes away quickly before I can read the rest of the message. Checked DIC code history, nothing.
Car runs perfect.
Is this anything? Just a start up, draw down sensitivity issue?
I will run a check on all ground connections.
Old Jul 6, 2009 | 02:19 PM
waktasz's Avatar
waktasz
I get a "charging system fault" code every once in a while on start up too. Doesn't seem to cause any problems any doesn't store and codes in the DIC. I see it maybe once every month or so. Slightly more often in the winter I think.
Torch FRC's Avatar
Torch FRC
Old Jul 6, 2009 | 03:44 PM
03 Z-oh-6's Avatar
03 Z-oh-6
How do u check DIC code history?
Old Jul 6, 2009 | 07:28 PM
ptindall's Avatar
ptindall
I get this too. I notice it happens after I had used the battery for a while after shutting the car off the previous time. For example, I kill the engine but listen to the radio for another 5 minutes before getting out. The next time I start the car I may get the Charge Fault warning. Mine's been doing that for years with no problems.
Old Jul 7, 2009 | 07:38 PM
99FewteRC5's Avatar
99FewteRC5
secure the terminals and connectors that plug into the alt. I was having the same problem, after i did that no message since.
To Odd, "Charge Fault" error message
