[Z06] Want do change tranny/diff fluid
Old Jul 7, 2009 | 12:56 PM
swollix's Avatar
swollix
Default Want do change tranny/diff fluid
I used the Royal Purple Synchromax in my M3, is this fine for the Z? I also used the Royal Purple gear oil as well. Also if I use them do I need to add any other additives for the LSD?
EDIT: Also, what weight gear oil is needed for the diff. and what size is the detent bolt for the Anti-venom mod before I start another "noob" thread?
Old Jul 7, 2009 | 01:37 PM
SeanMounce's Avatar
SeanMounce
Do a search, this is discussed often.
Old Jul 7, 2009 | 01:53 PM
iLLuZionZ's Avatar
iLLuZionZ
search noob!
Old Jul 7, 2009 | 03:33 PM
03 Z-oh-6's Avatar
03 Z-oh-6
Just used Amsoil ATF to service my tranny.
Also used Redline Gear Oil(w/ friction modifiers) to service my differential.
03 z06
Old Jul 7, 2009 | 04:42 PM
2K3Z06's Avatar
2K3Z06
From: KADS- If it has wings or an engine, I can break it. Dallas TX
Mobil 1, Redline, Royal Purple................ everyone has a different ansewer.
Which is better? Blondes, burnettes, or redheads...................
Old Jul 7, 2009 | 05:01 PM
03 Z-oh-6's Avatar
03 Z-oh-6
You can go wrong with any of the three oils.
However, I will say that brunettes are better!!
Old Jul 7, 2009 | 06:33 PM
Quick Silver Z's Avatar
Quick Silver Z
St. Jude 15 Year Donor
No-IL Events Coordinator
2025 C6 of the Year Winner - Unmodified
2019 C6 of Year Winner (appearance mods)
2018 C6 of Year Finalist
St. Jude Donor '12 thru '26
Amsoil ATF
Old Jul 7, 2009 | 06:55 PM
Stevo92z28's Avatar
Stevo92z28
Brunettes for me
Did i answer the right question?
Old Jul 7, 2009 | 10:47 PM
vms4evr's Avatar
vms4evr
I prefer all 3 of them. No additives.
My wife says I better not.
I run the RP Synchromax and MaxGear with no additives and their 5w30 oil. To answer the noob question
Old Jul 7, 2009 | 11:39 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
Depends on the fluid. Many gear lubes such as the AMSOIL Severe Gear Extreme Pressure Synthetic 75w90 I use come with friction modifier already in it and adding extra to prevent diff chatter is not normally needed for C5s and C5 Z06s. But, many fluids come without any additive and thus adding additive is required.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Jul 8, 2009 | 08:29 AM
AlwaysInBoost's Avatar
AlwaysInBoost
I've used royal purple max ATF in the trans and redline 75w-90 with the friction modifier (forget whether its the 90ns or regular 90) already included with good results. Recently I just switched to redline D4 ATF in the trans and can't really tell a difference between it and the RP Max ATF.
To Want do change tranny/diff fluid
