thinking about an engine change
Old Jul 11, 2009 | 02:35 PM
arkus's Avatar
arkus
Default thinking about an engine change
Pace performance has the ls3 for only 6k
Im considering putting it into my white 04.
Any comments ?
How much would a shop charge me for the swap ?
Old Jul 11, 2009 | 02:57 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Not sure on cost, but you can not go wrong with a LS3, more TQ down low and all the way through the power band, over the LS1/6
Old Jul 11, 2009 | 03:24 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
The LS3 is a great motor - without a doubt, but I believe you're going to encounter issues with compatibility on electronics.
Personally - I would go with an LS6 swap which will go much easier, since it was designed for the C5 electronics. You could do a mild cam and heads with an LS6 crate motor and accomplish the same horsepower output.
It's probably in the range of about 12 hours of shop time, so you might start calling around and asking shop rates. Don't forget to have a professional tune on the engine to maximize driveability and performance.
Old Jul 11, 2009 | 04:14 PM
SCM_Crash's Avatar
SCM_Crash
LS1 to LS6 swap isn't worth the money. And the LS1 block is actually a bit stronger because the cylinder walls aren't as thin. Heads/Cam on the LS1 would be smarter than that swap.
However, the LS3 should go in just fine into the 04 as long as the computer's coming with it. The LS3 uses a 58x reluctor and the LS1/LS6 uses a 24x reluctor. So the computers aren't compatible. But if the LS3 computer is installed, there shouldn't be any problems.
Old Jul 11, 2009 | 04:21 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
There are plug n play conversion harnesses for the crank reluctor and the couple other sensor differences.
It's basically a drop-in swap nowadays.
Old Jul 11, 2009 | 04:32 PM
Lancejoker's Avatar
Lancejoker
ECS has done it,hell they put a LS7 in one of their cars.
Old Jul 11, 2009 | 08:13 PM
arkus's Avatar
arkus
pace performance has 2 versions of the Ls3
1. the stock one.376/430 hp 6,189$
2. the 480 hp with a hotter cam376/480 hp 6,529$
The ls7 is 13,600 .
I think 6,500.00 is not bad for a new engine with a 24 month warranty.
Old Jul 11, 2009 | 08:14 PM
SCM_Crash's Avatar
SCM_Crash
Is that installed?
Old Jul 11, 2009 | 08:22 PM
arkus's Avatar
arkus
I dont know how much instalation will be..depends on the shop.
Old Jul 11, 2009 | 08:29 PM
SCM_Crash's Avatar
SCM_Crash
Hrmm... I don't know if I'd do it. I think I'd rather go h/c, full exhaust and tune. Get more power for about the same money and that includes install.
Old Jul 11, 2009 | 08:35 PM
arkus's Avatar
arkus
That might be easier
How much hp would I get
Old Jul 11, 2009 | 08:48 PM
SCM_Crash's Avatar
SCM_Crash
Depends on the heads/cam package, the exhaust you go with, and the tune.
You live in CA where exhaust is a problem (nothing carb certified that I've found). So that's going to be a limiting factor unless you find a smog shop that understands the "wink".
Heads/Cam alone will be around 60-80RWHP
Depending on the cam you get, you'll need a tune.
With tuning on - say - a TSP 233/239 cam with Stage 2.5 LS6 heads, you'll probably see 410 to the wheels. With full exhaust, maybe 430 to the wheels.
The LS3 is only going to see about 370 to the wheels.
You may need injectors at that point. 36# injectors will cover that.
So, cost wise:
TSP h/c package is about $1800
Full exhaust is about $2000 with cats and X-pipe
Injectors are about $250
Tuning (GOOD dyno tuning) is about $500.
I don't know what they charge right now for installation of all the parts, but so far you're looking at $4600 (with misc parts like gaskets). I'd imagine as a package deal, install would put the total cost at around $7K. That's definitely cheaper than installing an LS3.
I'm sure what ever shop you get to install everything will cut you a good deal on the dyno tuning.
Old Jul 11, 2009 | 09:52 PM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
I'd go the LS3 way over the heads cam option.
First, you end up with a new engine. Lingenfelter and a few other companies make all the harnesses and adapters you need to make it a plug and play swap, so difficulty isn't a factor.
The hot cam version gives you 480 at the crank, 408 at the rear wheels. Me, I'd skip the hot cam and go to a bigger cam. Clean up the heads and intake and you'll be well over 450 at the rear wheels with plenty of room for growth.
If you go the heads/cam option when you're done, you're done. To get any more out of it you'd need to spend some serious cash. And you've still got an engine with miles on it.
The LS3 will dollar for dollar always out perform the LS1 thanks to more cubes, bigger heads and better intake. A little more up front for a lot more down the road.
Old Jul 11, 2009 | 10:09 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
Isn't ECS (or one of the other vendors) offering a new supercharger kit for around 6k INSTALLED?
That would blow the doors of a modded LS3
Old Jul 11, 2009 | 10:17 PM
SCM_Crash's Avatar
SCM_Crash
This is true, but at the same time, you're talking about a bit more money for the misc parts and the installation. Also, does the LS3 come with the LS3 exhaust or are you going to be reusing your current LS1 exhaust? That's going to limit the amount of power you make as well, so 408RW may not be the case. If it does come with the LS3 exhaust manifolds, you're going to need some exhaust work done to make your current piping work.
If money isn't an option and you don't mind spending $2-3K more than the LS1 with h/c, than I'd do the LS3 as well.
Old Jul 11, 2009 | 10:18 PM
Mark C5's Avatar
Mark C5
I wouldn't say it would blow the doors off it. The Vortech running a safe boost level of say 6-7 psi will get you a gain of about 150 at the crank. That comes out as 425 at the rear wheels. A modded LS3 could easily top that.
Numbers came from the Vortech site.
Old Jul 11, 2009 | 10:20 PM
Mark C5's Avatar
Mark C5
I would think LT headers would be a given with either option, so price wise they equal out.
To thinking about an engine change
Old Jul 11, 2009 | 10:24 PM
Stevo92z28's Avatar
Stevo92z28
Sky is the limit. How far do you want to go? Are you bone stock now? How much hp do you want or "think" you want? Then we can suggest some ideas. Do you want the car to lope? Do you want it quite, like stock? MPG an issue? Honestly easiest way to make the most hp and keep stock drivability with no inspection issues would be a blower and probably cheapest or just as expensive as an new ls3 installed but make A LOT more hp.
Me personally i'm always on a budget...best bang for buck would be a H/C package and staying with what you got now. How many miles on your car? The bottom end in these cars can take a H/C package easy as well as 6lbs of boost...so ya in the end it comes back to the questions i asked in the beginning of my post.
Old Jul 11, 2009 | 10:26 PM
SCM_Crash's Avatar
SCM_Crash
Not really. Depends on if he wants to stay smog legal. Here in California, (which is where he is as well) there aren't any smog legal options for LT headers. I'm still looking around for options for my Z06. I may just get the LG Pros and give the shop guy a good tip. But we don't know if the OP wants to do that.
Old Jul 11, 2009 | 10:32 PM
Mark C5's Avatar
Mark C5
I really didn't take the Calif thing into consideration and should have. I believe there are a couple brands of shorties that are smog legal and though not as good as LT's are an improvement over stock. Either way, the LS3 is still going to outperform the LS1.
