Solution for the corroded alternator.
Jul 13, 2009 | 05:04 PM
I was tired of looking at all the corrosion on my alternator. I am not finished because I ran out of battery. Here is a brief view to what I am doing.
I used my dremel to do all the work
I used this wire brush. It is worn because I used it to clean my calipers before painting.
The old look with a little clean spot.
All new look
Here is a video of how I did it. I only worked on this for about 15 minutes. 30 if you count the pictures.
It is not perfect but I am much happier. Once the dremel recharges I will shine it up some more. I may spray it with clear coat too.
Jul 13, 2009 | 05:07 PM
Looks great
Did the same to mine with a 18volt drill and wire wheels did all the castings on engine.
Reason: added pics
Jul 13, 2009 | 05:16 PM
Jul 13, 2009 | 05:21 PM
looking good, both of you!
Jul 13, 2009 | 06:04 PM
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
I've got to ask how much dust and other crud wound up inside the alternator?
Jul 13, 2009 | 06:12 PM
Would it be beneficial for someone to hold a vacuum mozzle close by while doing this? I'm thinking all that metal dust inside an electrical device can't be a good thing.
Jul 13, 2009 | 06:24 PM
Quote:
Originally Posted by
Blue 92
Blew everything out with a air hose when i finished.Did mine quite a few months ago and no issues.
Jul 13, 2009 | 06:39 PM
Could use a small buffing wheel and compound......less loose metal that way
Jul 13, 2009 | 06:45 PM
Amazing what a little metal brush can do!
Jul 13, 2009 | 07:13 PM
great job guys
Jul 13, 2009 | 07:17 PM
Nicely done
Jul 13, 2009 | 07:43 PM
Anyone try Blingmaster on their alternator yet? Looks like it can do wonders for everything else.
Jul 13, 2009 | 08:17 PM
dust didn't occur to me. Still works though. I think they are pretty hearty.
Jul 13, 2009 | 08:39 PM
Looks like a good way to bring the alternator back to life in the looks department.
Jul 13, 2009 | 08:49 PM
ecoman
Jul 13, 2009 | 09:08 PM
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
be sure to keep it out of the salt spray this winter, or it will look the same as when you started; otherwise brush on some POR 15.
Jul 14, 2009 | 12:20 AM
What an improvement
I think I just found a new job
Jul 14, 2009 | 12:22 AM
This is the first thing on my TO DO list.
EDIT:
Well I just couldn't stand it. Went to Lowe's and picked up a brush for my drill and my Dremell along with some Scotchbrite pads. When I got home I hit the alternator with the pad and was AMAZED at the change. Spent about an hour hitting the alternator, bracket and throttle plate housing. I will post some pics tomorrow (thurs)
Jul 14, 2009 | 12:54 AM
Jul 14, 2009 | 01:13 AM
I do want to do this to some stuff on the car (rear crossmember, yokes in the wheel well) but I was wondering if it would remove some kind of anti-corrosive coating or something?
Couldnt wind up any worse after I clean it up (long after I mean, like next year)?
Anyone do this and have a few years on it?
