steering column/dash rattle
Old Jul 18, 2009 | 04:19 PM
LaMagred02's Avatar
LaMagred02
Default steering column/dash rattle
Last week a rattle began coming from either the dash or the steering column. It only happens on bumpy roads. It sounds like marbles or plastic items hitting together. Needless to say, it is VERY annoying. Any idea what is causing this?
Thanks.
Old Jul 18, 2009 | 04:41 PM
JerzeyJoe's Avatar
JerzeyJoe
I had a similiar problem. I thought the rattle was coming from the dash. I read somewhere on this forum to check the hood stops. I did and raised the stops a little, rattle is gone. Give it a try.
Old Jul 18, 2009 | 04:53 PM
LaMagred02's Avatar
LaMagred02
what did yours sound like before you fixed it?
Old Jul 18, 2009 | 05:41 PM
JerzeyJoe's Avatar
JerzeyJoe
It was a rattle with an occasional thump. It was louder when the car was first started mostly in colder temps. Once I drove it a couple miles and the car warmed up it would go away. Hope this helps because I know rattles aggravate me.
Old Jul 18, 2009 | 05:45 PM
JCamaro's Avatar
JCamaro
Thanks.
My clamshell rattles slightly....someday I'll split it and put some foam tape on each side for a rattle free clamshell mod
Old Jul 18, 2009 | 07:01 PM
SuperTom's Avatar
SuperTom
I just finally fixed this problem after taking the whole dash apart and lubing and padding everything it didnt fix it. Turns out the noise was actually coming from the latch for the targa top. I lubed that up and adjusted it slightly lower problem solved!!!
Old Jul 18, 2009 | 07:07 PM
redrckt97's Avatar
redrckt97
this was exactly what I found - swore there was a noise in the dash - but some white lith/ grease on the hatch latches and some in the cavity where the locating pins ride fixed it completely
Old Jul 18, 2009 | 07:21 PM
LaMagred02's Avatar
LaMagred02
tried it....rattle is still there
Old Jul 18, 2009 | 07:23 PM
LaMagred02's Avatar
LaMagred02
are you talking about the targa top latches as well?
Old Jul 18, 2009 | 07:26 PM
ZYa's Avatar
ZYa
I had a rattle problem with the screws at the bottom of the bolster. They were not screwed with the nuts or whatever is down there. I made sure to screw them into properly and the rattle noise was gone.
Old Jul 18, 2009 | 07:32 PM
Trpblk04's Avatar
Trpblk04
Needle in a hay stack...
Old Jul 19, 2009 | 11:46 AM
LaMagred02's Avatar
LaMagred02
Old Jul 20, 2009 | 01:45 AM
c5blkvetteguy's Avatar
c5blkvetteguy
I have a rattle as well. My dash was taken out for the stereo install and is still there. The funny part is when I turn the tunes up.....rattle is gone! lol.
To steering column/dash rattle
