[Z06] go faster
I'll list the mods on my former C5Z in order of what I perceive to have been the best bang for the buck:
DRIVER MOD - This is worth about a 0.75-1.5 second drop in ET
275x40x17 Hoosier DRs on stock front Z wheels - 0.2-0.5
GTO Spares for the front - 0.1
4.10s with hardened shafts - 0.2-0.3
Vararam, 1 7/8" ARH, Dyno Tune - These should be done in combination since they will produce the biggest gains in HP. It will save retuning your car. - 0.4-0.6
Textralia Exo-Skel - Great clutch to put the power to the rear. I see that you are going with a cam. Your stock clutch will not stand up for long with your new found power. - 0.1
Good luck in your quest. Let us know how you make out.
You may wish to perform some research prior to posting.BTW- I see that you run those other headers. That would explain your response.
Official C5 Z06 Fast List
By Ranger, Robert56 and Gary2004Z06
C5 Z06 External Bolt On Times (stock long-block)
1--10.890@125.06--1.465--GARY2004Z06--'04 12/08-VR CAI, DRs, ARH LTs, Clutch, Gears, Post 356
2--11.214@122.30--1.580---Dr Ron -------'03 11/05-VR CAI, ET St, LT, ClutchSlip
3--11.25x@123.7x--1.58x---Butcher-------'03 10/04-Bolt Ons, 3.90 gear
4--11.37x@123.7x--1.48x---PaulZ06-------'0x xx/xx -Bolt Ons, 3.73 gearVideo
5--11.405@123.61--1.616 --Qksiver-------'02 01/05-VR CAI, NT DR, Clutch Slip
6--11.442@122.51--1.643---spindoctor----'01 01/07-ET ST, CAI, LT
7--11.461@119.79--1.634---procs2v-------'02 04/08-HT CAI, MT DR, LT, Post 220 Video
8--11.566@119.50--1.772-Robert@SpeedDemon-'04 02/09-CAI, BFG DR, LT, Post 380
9--11.598@119.38--1.722---N75196-------'04 03/07-LT, VR, Clutch, MT/DR Slip
10-11.62x@11x.xx --1.66x---holedgr -------'02 xx/xx -Bolt Ons
C5 Z06 External/Internal Bolt On times (stock cubes, n/a, cams, h/c, all bolt ons)
1---9.985 @ 138.80--1.428 --robz ---------'03 04/08 -----H/C, ET ST, Gears, Post 328, Slip (Rob's car has been as quick as 9.93)
2--10.672 @ 126.17--1.449--J Rod---------'02 xx/xx -----H/C G5X3, ET St, 4.10
3--11.108 @ 127.41--1.687--Kurtomac-----'02 03/09-----H/C/I, LT, VR, Clutch, 3.90's, ET ST, Post 385
4--11.206 @ 123.32--1.663--Quick 68 -----'03 02/09-----CAI, UD pulley, cam, Post 382
5--11.331 @ 120.33--1.642--pit-man-------'03 02/07 -----H/C/I, LT, ET ST Slip
6--11.399 @ 121.37--1.59x--427CPE-------'02 11/07-----H/C, ET ST Radial, LT, CAI, Post 235, Slip -Video
7--11.41x @ 120.43--1.61x--NightmareZ06-'02 09/07 -----Cam, LT, CAI, BFG Info
8--11.584 @ 122.86--1.727--02Thief -------'01 11/06------ET RDs, LT, Cam, 3.90s, Post 3 Slip
9--11.586 @ 119.84--1.592--n751961-------'04 05/08------LT, VR, Gears, Cam, Post 284
10-11.601 @ 123.62--1.92x--ZZoomM06-----'03 11/07-----H/C/I, VR, Post 219 Slip
Your 11.4s are definitely attainable; however, it is not easy with your budget constraints. Concentrate on the minute details to extract out every bit of ET. Weight loss is free. You can remove your passenger seat and cut +/-0.03.
Good luck.
There are plenty of dynographs comparing the LG's to the ARH on the same cars and the LG's pick up almost 30tq in the lower and mid range RPM's while making about the same peak numbers. Also going with 1 7/8 headers is worthless on our 346ci engines. They arent even worth any meaningful extra hp until you go more then 400ci. There has been plenty of guys showing that they didnt pick up any tq at all and made maybe an extra 3hp in the very top RPM's. And that is on bigger bore, bigger cubes and supercharged LS2's and LS3s making more then 600rwhp.
And also ARH are overpriced for what they are considering there was very little R&D that went into them compared to LG and kook's. This is because the guy who runs/owns ARH left Kooks and basically copied their design for the ARH design.
Meanwhile I ran a bunch of 11.50s with 363 rwhp in a 02 Z06 with only non-stock parts being a cold-air intake and DRs.
So the place to start is leaning to drive the car at its current power-level and then add power once you can run low-12s or better stock, with stock tires or DRs.
The OP is within easy driving distance to three good tracks, MIR, Capitol, and Cecil County. Great places to learn the car.
Ranger
Gallants Auto
309 S Atwood Rd
Bel Air, MD 21014-4191
(410) 838-2355
Jack
http://www.rangeracceleration.com/Launch_Tips.html
and improved shifting.
http://www.rangeracceleration.com/Im..._Shifting.html
You may be fortunate enough to meet Ranger at MIR.
This is where I started. I then became friends with robz and he increased my performance through advice on part selection, setup, and additional launch techniques.
And maybe your brand is swaying your pov.
Your list dosent really prove anything and turning this into another header war is pointless. The brand of header is not going to make a difference until you get more displacement and there have been plenty of dyno reports proving LGs low speed power, do a search.
It will not matter what brand he chooses whether it be Kooks ARH or LG, they will all pretty much preform the same function, just at different points in the power band. Again, 5 or 6 hp is not going to make a difference for the OP. So rather than start a header war, try and help w/o bias.
1) Who started the header discussion?
2) More importantly, who is attempting to assist the OP?
If you or longrodlx have anything of substance to add to help the OP reach his goal, please do so.
... anyone know of a good shop with a dyno near Annapolis, MD ??
