electrical problems
Old Jul 22, 2009 | 06:21 PM
ejackson's Avatar
ejackson
1st Gear
Default electrical problems
I have a 01 c5 and my windows and door locks do not operate and I have checked the fuses.
Old Jul 22, 2009 | 09:49 PM
Allzwell's Avatar
Allzwell
St. Jude 15 Year Donor
Cruise-In VIII Veteran
St. Jude Donor '03 thru '20
Have you checked the codes via the DIC?
If you are getting "NO COMM" codes it's a simple fix.
If you are getting "NO COMM" codes it's often a short within the wire harness leading from the car frame through the accordian tube to the door. There is a clear tube covering a bare wire that is often the cause. Put some electrical tape over the exposed bare wire and your code should go away and your windows & lock should operate.
Old Jul 22, 2009 | 11:02 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Neither side works ?
I doubt that you have two bad modules. What codes are you getting ?
The "diagnostic display" mode is entered with the following procedure:
1. Turn on the ignition but don't start the engine.
2. Press the "reset" button to turn off any warning messages
3. Press and hold "options" and
4. While holding "options", press "fuel" four times within a 10-second period.
Old Jul 22, 2009 | 11:22 PM
DeeGee's Avatar
DeeGee
When you say they dont work, is that using the fobs, using the switches or both?
To electrical problems
