Red Plug Wire Question
Old Jul 25, 2009 | 10:30 AM
robsc501's Avatar
robsc501
Default Red Plug Wire Question
Hi There:
To those of you who have used the red wire set p/n12495519.Does the wire end that connects to the ignition coil have a white ceramic insulator like the factory black ones do?
Thank you
robsc501
Old Jul 25, 2009 | 10:43 AM
Tigershark3's Avatar
Tigershark3
Neither my stock '99 wires or the red GM performance wires had ceramic. The plug end had a metal shield and the other end had a rubber boot as I remember. Use dialectric grease on the plug end to make it easier to get off later.
Old Jul 25, 2009 | 11:54 AM
DeeGee's Avatar
DeeGee
The GMPP Reds have black rubber boots - no ceramic. I fitted the metal heatshield back to the new leads
Old Jul 25, 2009 | 01:06 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
We use the GM red wires almost exclusively....great perfomance, perfect fit and reasonably priced. No ceramic ends, though.
Old Jul 25, 2009 | 02:19 PM
bighank's Avatar
bighank
Default Same here
BIGHANK
Old Jul 25, 2009 | 04:57 PM
robsc501's Avatar
robsc501
Hi There:
I think you guys miss- read this thread.I appreciate all your replys. If you pull the wire off the coil & look in the end of the wire, you will see the metal round contact. Is there a white insulator below that on the gmpp red wires?
Sorry if I was not clear in the earlier post.
robsc501
Old Jul 25, 2009 | 06:20 PM
Old Rotor Head's Avatar
Old Rotor Head
Me too, not sure what you have there
Old Jul 25, 2009 | 11:11 PM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
Sounds almost like you have a broken plug. No ceramic in any plug wire I've ever seen. Is it in every plug boot?
Old Jul 25, 2009 | 11:53 PM
That's how mine were.
Old Jul 26, 2009 | 12:19 AM
DeeGee's Avatar
DeeGee
Originally Posted by robsc501
Hi There:
robsc501
All I can see is the metal clip
Old Jul 26, 2009 | 08:51 AM
rws.1's Avatar
rws.1
only metal here too
Old Jul 26, 2009 | 08:08 PM
robsc501's Avatar
robsc501
Hi There;
Thanks Dee Gee and rws.1 for the info. I was looking for. Thats how gm saved money on the red wires($60.71) by not including that insulator to divert heat away from the coil pack.The black factory wires have this insulator, but they cost $127(my cost) list for $181
robsc501
Old Jul 27, 2009 | 01:58 AM
PierEagle's Avatar
PierEagle
As the OP states, the stock wires from my '98 have the ceramic in the coil end (not the sparkplug end) of the wire. It encircles the metal connector. I changed to the red wires awhile back and still have the stock wires in my treasure chest of used parts.
Old Jul 27, 2009 | 07:10 PM
robsc501's Avatar
robsc501
Hi There:
Thanks Pier Eagle. You know the corvette!i have a big treasure chest too.
robsc501
To Red Plug Wire Question
