ok i put on my new corner lights, but i want to switch the bulbs with LED's so i dont burn thru the top of the housing again. i want to buy some that fit right into the stock socket. am i going to get hyperflash from this? if so, how do i fix it? any suggestions on products? thanks!
The man you need is Jhonathan at "JW Motoring." He is a knowledgable vendor and forum sponsor. His integrity is second to none. If he can't help you, no one can.
Best wishes.
Glen
Also talk to Richard at Corvette Enhancements (C5VetteLS1 on here). They are a supporting vendor as well.
Yes, if you just install LED for corner lights, you will get hyperflash. Richard has a bypass harness that plugs in under the dash. well worth it IMHO.
I went with switchbacks, these change from amber (DRL, turn signal) to white (parking/marker light), and they are
i did not see a link in that thread for the harness though. i also looked on the jw motoring website, and didnt find it there either. do these switchbacks fit into the stock bulb socket?
I don't have the harness on the site. I can point you in the right direction for one though.
Yes my bulbs fit right into the socket. You might look at some LEDs for the front corners also. It will look a lot better.
where would you suggest i acquire the harness? im going to purchase both the switchbacks and the corner led's. are there different harnesses for different led setups? for example, if someone only wanted to do the running lights and leave the corners incandescent. i just want to make sure i purchase the correct harness. i do not plan on going LED tail lights.
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
No the harness is for everything. You need to remove the center console to install it though. I think I just noticed a PM from you. I haven't had a chance to respond to them all yet.
