[Z06] Stupid question
Old Jul 28, 2009 | 03:45 PM
yellow 02 Z06's Avatar
yellow 02 Z06
Default Stupid question
Ok so Im trying to finish up my supercharger install. I keep running into little things to slow me down. My question is, can I install the MAF before boost? ie can I install it right after the air filter right before the supercharger? The instructions show it install right before the throttle body, but I cant do that on mine. The reason is, I bought my kit used and its a bit of a custom kit. The guy that had it before me had a speed density setup so he didnt have a MAF, so the couplers and piping I have wont fit on the MAF. Ive been everywhere trying to find some couplers and reducers that would work with no luck. So once again, can I have my mass air meter before the supercharger compresses the air and it work fine?
Old Jul 28, 2009 | 03:50 PM
yellow 02 Z06
Default oops
I probably should have posted this in the FI section but oh well. Im sure someone can help me.
Old Jul 28, 2009 | 04:11 PM
BPG's Avatar
BPG
not really a specific answer for you, but there is a difference between a drawl through and a blow through MAF. im not sure which you have...
hope this helps.
Old Jul 28, 2009 | 04:54 PM
yellow 02 Z06
I have the stock MAF. I wouldnt think it matter because if I had a Maggie or a KB set up, the MAF would have to be before the supercharger. I remember on my mustang, I had a KB so the maf was before boost. Anybody know for sure?
Old Jul 28, 2009 | 08:42 PM
CUZIWIN's Avatar
CUZIWIN
On a Kenne Bell the blow off valve just recirculates the air through the supercharger. On a centrifical the blowoff vents to the atmospere. I think this is the main reason most guys blow through the maf. It's harder to tune if your maf measures air that your blowoff vents out and never gets to your motor.
Old Jul 29, 2009 | 08:13 AM
Over-torque's Avatar
Over-torque
construction wise, it doesn't matter weather you have the MAF before or after the air is compressed. as stated above it's called draw-through vs blow-through. it will be addressed when the car is tuned. same with the above statement about the recirculation valve. some blowers (for example, KB, Eaton, Vortech) recirculate back into the intake and some (Procharger likes to do this) vents to atmosphere. thats really the difference between a bypass valve and a blow-off valve. a good tuner can make either work.
in my experience, in the past blow-through tuning has been a little more "particular" when tuning. i.e. rotating the MAF can actually change the AF ratio without my changing the MAF transfer function. but, modern electronics seem to be better in that regard now.
Old Jul 29, 2009 | 12:57 PM
yellow 02 Z06
Thanks that helps alot. So since it seems like it will work, Ill leave the MAF before the supercharger and let the tuner handle it.
To Stupid question
