A/c vent prob
Old Jul 28, 2009 | 07:00 PM
ditoc5's Avatar
ditoc5
Navigator
Default A/c vent prob
I got confermation from an a/c guy that my compressor is fine,the line is cold but getting lots of hot air. sounds like a vent prob any ideas.
Old Jul 28, 2009 | 09:09 PM
floridarob's Avatar
floridarob
Try turning off the a/c and disconnecting the battery for 10 minutes or so. When you reconnect battery and turn on car the air blend vents reset. This works *sometimes* or at least has for me when the passenger side is blowing cold and driver side blowing hot.
Old Jul 29, 2009 | 07:35 AM
Hvymtlc5's Avatar
Hvymtlc5
One of your HVAC actuators is not working properly. Check your codes...look for one of these:
B0441 Left Actuator Out of Range
B0446 Right Actuator Out of Range
You can try the battery disconnect. If that doesn't work the faulty one either needs to be taken apart and re-indexed (do a search) or just replaced.
To A/c vent prob
