Slowing sequencial turn signals
Old Jul 29, 2009 | 10:09 AM
Florida Mike's Avatar
Florida Mike
Default Slowing sequencial turn signals
Hi,
I installed a sequencial turn signal kit on my 04 and as others have said it is very cool. Very easy to do too.
However, I would like to slow down the sequencing between the flash of each light. The instruction suggested different bulbs like 3357 or 4157 which are higher wattage than the OEM 3057 but I tried that with no improvement.
On a regular car you could install a heavy duty flasher but I know the C5 runs the signals through the hazard flasher module which is not an easy plug and play replacement.
Any other thoughts? As I said, the mod works fine and it does look cool. I just want it to slow down a bit.
Yeah, I know I am a picky pain in the a**. Wife tells me that all the time!
Old Jul 29, 2009 | 10:46 AM
Bills03Coupe's Avatar
Bills03Coupe
Originally Posted by Florida Mike
Hi,
I had the same problem with mine. The sequence was two fast. I checked with the manufacturer and he said the C5 Flasher is in the hazard switch and a PITA to change out. He also mentioned a bypass harness that is available from a forum Vendor (didn't have his name, and suggested doing a search) that allows you to plug in a different flasher without tearing your dash apart.
Old Jul 29, 2009 | 10:48 AM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Hi,
If you're getting hyperflash, you can either use load resistors or a hyperflash bypass harness. If you're already getting standard flash, the only way to change the flash rate is to add a capacitor to the flasher electronics. This should slow the flash rate by increasing th amount of time needed for the circuit to build up the power to discharge.
Old Jul 29, 2009 | 10:57 AM
tramminc's Avatar
tramminc
Old Jul 29, 2009 | 11:08 AM
LoneStarFRC's Avatar
LoneStarFRC
Originally Posted by 8VETTE7
I'm about to order one of the sequential flasher setups. What is Hyperflash and what causes it????
Very rapid signal rate caused, most commonly, by the swapping out to LED bulbs from the common OEM incandescent bulbs.
Btw, the subject of the OP is about sequential flashers, which have their own timing circuits, etc and not really a part of the "hyper-flash" problem as far as turn signals generally.
Old Jul 29, 2009 | 11:26 AM
Brian@FI Performance's Avatar
0Brian@FI Performance
Former Vendor
From: FI Performance : Norwalk Connecticut www.FIPERFORMANCE.com
Hyperflash is what happens when the load from the bulb/led is not enough so the car thinks a bulb is out thus doubling the flash rate. This sometimes happens with Halo LED Tail Lights on very rare occasions which can sometimes be reset by doing a certain de-install/re-install procedure. In the event that that does not work, I can supply you with the relay/harness bypass kit for $69 plus about 5-8 for shipping. for those that want to use paypal, you can by sending $74.99 to:
brianrosenberg@gmail.com
You can also get the exact product info here...
or PM me your phone number and I can take credit card over the phone.
You would need this relay if you were to do LED's up front anyway.
Brian
Old Jul 29, 2009 | 12:46 PM
Bills03Coupe
I don't think Florida Mike is talking about hyperflash. What he wants to do is slow down the sequence (a slightly longer delay between each tailight flashing)
Old Jul 29, 2009 | 12:47 PM
jrose7004's Avatar
jrose7004
I've thought about getting one of those kits but haven't.
Old Jul 29, 2009 | 12:55 PM
LoneStarFRC
Precisely.
Old Jul 29, 2009 | 01:51 PM
cgilbert23's Avatar
cgilbert23
I have never heard of sequentials on a vette...that would definatley be a cool feature. I just did a youtube and nothing come up. Anyone have a vid of their C5 with the lights?
Old Jul 29, 2009 | 03:49 PM
Florida Mike
Just do a Yahoo or Google search and a few vendors come up. One even just posted last night I believe.
They are pretty cool.
Old Jul 29, 2009 | 03:50 PM
Florida Mike
Yes to all who said I just want to slow down the sequence. I don't think a bypass harness would work as I don't have Hyperflash just want to slow the seqence between the two lights flashing down.
I think thats why the manufacturer says use a different bulb. As I said its probably slow for most folks but I want it slower...dammit!
Old Jul 29, 2009 | 04:10 PM
2KFRC5's Avatar
2KFRC5
http://webelectricproducts.com/
Old Jul 29, 2009 | 04:18 PM
Bills03Coupe
Mike, the harness I was talking about allows you to change out the flasher without ripping the dash apart. There is a vendor on this or possibly another forum, that sells them.
Old Jul 29, 2009 | 05:06 PM
Florida Mike
Bill,
OK, thanks. Maybe thats what I need to look into.
Mike
Old Jul 30, 2009 | 07:41 AM
clif's Avatar
clif
St. Jude Donor '09-'10
I want to see how to slow down the standard flash rate too! I have the sequencial kit as well.
Old Jul 30, 2009 | 09:17 AM
LoneStarFRC
It can be done. It would require a modification to the existing sequential timing circuit and would thereby increase the cost due to additional components, etc. It wouldn't necessarily dictate a HUGE increase in price, but there would be one just the same.
The circuit would (should) have adjustability for the end-user so that everyone can adjust the rate of sequential flash to suit themselves. What is "fast" to some, is "OK" to others, etc, etc.
The flasher in the dash or the "adapter harness" to use another flasher, is not the answer here.
To Slowing sequencial turn signals
