A hole in muffler?
Old Aug 1, 2009 | 04:21 AM
karateboi87's Avatar
karateboi87
Default A hole in muffler?
Ok I was recently checking out a Z06 TI exhaust in F/S.. and apparently it has a 1/8" hole on the side of the muffler.
Would exhaust gas leak or have some sort of a functional problem?
Or would it sound weird since muffler is the "silencer"
Any help is appreciated.
Old Aug 1, 2009 | 06:13 AM
SeanMounce's Avatar
SeanMounce
Are you talking about the drain hole at the bottom part of the side.
Old Aug 1, 2009 | 06:52 AM
WKMCD's Avatar
WKMCD
It's to let the condensed water drain out. It's supposed to be there.
Old Aug 1, 2009 | 08:24 AM
rebelheart's Avatar
rebelheart
LOL factory installed hole,normal!
Old Aug 1, 2009 | 03:55 PM
karateboi87
No. I asked the seller if there's any damage to the mufflers or the tip. And he said there's a hole 1/8 inch on the side of 1 muffler. I don't think he's talking about factory holes.
If so, he wouldn't have to tell me as that's how it's supposed to be.
All I want to know is whether it affects the functionality... No one is going to crawl under my car and look "hey there's a little hole there"
Old Aug 1, 2009 | 04:12 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
If it has a non factory hole in it I would pass , There are a ton of TI exhaust out there unless he is giving them away, Last thing I want to do is install something that isn't right. There is a chance the whole can get bigger over time and then toy would be bummed when your car starts to backfire.
Maybe that is just me...
Bill
Old Aug 1, 2009 | 05:07 PM
karateboi87
Bill
You could be right.
I never understood how a TI had a hole in it in the first place. As far as I understand, TI's are very strong and durable. You're not supposed to have to replace the system for the vehicle's entire life.
He's giving a decent price.. I just don't want to be stuck with something I have to replace later.
Old Aug 1, 2009 | 05:31 PM
itzza427's Avatar
itzza427
All mufflers will build condensate,,especially if there are a lot of short trips. As far as I know,,just about all mufflers have a "weep hole"to let it drain,,or else every time you got on it it would look like a Stanly Steamer taking off!! Does it look like it belongs there?? Even my full stainless Corsas have one!!
Old Aug 1, 2009 | 06:19 PM
karateboi87
I don't have a picture of the hole, so I'm not sure.
So in reality, even if there is an extra 1/8 inch hole, it will just be another outlet for draining.. It really shouldn't affect its performance or sound, correct?
Old Aug 1, 2009 | 06:33 PM
VinnyT's Avatar
VinnyT
Right. The hole will look like it was put there on purpose.
Old Aug 1, 2009 | 06:38 PM
karateboi87
Old Aug 1, 2009 | 07:57 PM
itzza427's Avatar
itzza427
All the ones I've seen are at the bottom at the lowest point tight at the point of the end cap/body seam or junction. It should look like when the muffler is installed the hole would be at a low point where the moisture can drip out. The holes are so small it makes no noticeable sound! Hope this helps!!
Old Aug 1, 2009 | 08:16 PM
Smadoo's Avatar
Smadoo
I dont know about your state, but in PA, a car will fail inspection if there is any holes anywhere in the exhaust that are not supposed to be there.
Old Aug 1, 2009 | 08:40 PM
BOTYNV1's Avatar
BOTYNV1
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
He will be fine here, and I agree it should not pose an issue. I have yet to see your car
Old Aug 1, 2009 | 10:27 PM
rebelheart's Avatar
rebelheart
Maybe he doesnt know that the muffler is supposed to have a hole(the seller).
Old Aug 2, 2009 | 12:17 AM
If that's where the hole is, it is supposed to be there - and will not affect the performance of the muffler at all.
Old Aug 2, 2009 | 02:48 AM
karateboi87
You guys may be right, but I think he said "on the side of one muffler" or something like that.
Anyhow, the reason I asked this question is because sometimes I hear VERY loud exhaust coming in from some 1980's honda, and obviously there's some holes in the exhaust...
So small holes don't matter, while bigger ones do? I don't understand the sound part of exhaust systems
You can see it in my profile or just look under the threads I started.. you'll find the one about my trip to Florida.
Hey, we should go cruise together on a weekend or something. I know you're in Rochester. I'm on the west side of Springfield, like 5 minutes away from White oaks Mall.
To A hole in muffler?
