Pcv
Old Aug 4, 2009 | 12:18 AM
onevettenut's Avatar
onevettenut
Default Pcv
Guys. I need a little help and I know this is a stupid question but here goes.
I need to know where the PCV valve is on the 01 C5.
Thanks for the help
Old Aug 4, 2009 | 12:37 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I'll take a guess that its the same place as on the '99 that I had. It attaches to the intake on the forward passenger side of the engine. Its got what looks like a heavy ground wire on it which is in fact a heat transmission method. The rubber hose/coupler from the valve to the intake can collapse with age too, so it needs to be looked at from time to time.
Old Aug 4, 2009 | 08:17 AM
onevettenut
Thanks I am sure to find it
Old Aug 4, 2009 | 08:23 AM
robsc501's Avatar
robsc501
Hi There:
dgrant3830 is correct.When I changed mine on my 01 I used a spark plug boot puller as that puppy was really in there.Heres the a/c delco p/n cv948c.I changed mine at about 15k. Nothing wrong with the factory one, but having the new one handy made it easy to find the location of it & I figured I might as well change it, since I had it out. New one costs about $6.00 from the dealer.When you get the old one out blow(by mouth) in 1 end you get resistance ,the other end no resistance.ops. check ok.No replacement required.
robsc501
Old Aug 4, 2009 | 08:34 AM
onevettenut
Thanks for the part number.I am going to get one and replace it even if it checks OK.
Car has 40K and I don't know when replaced last.
Old Aug 4, 2009 | 09:28 AM
robsc501's Avatar
robsc501
Hi onevettenut:
No problem.Good idea to change it anyway.My aunt was born & raised in Lebanon,Pa.married a guy from Dixson,Il. during the war.I have some cousins still living there. I lived in O'fallon,Il. close to Scott AFB.our son was born at the base hospital. I also have a cousin living in Collinsville,Il. Which one are you close to?
Have a good day
robsc501
Old Aug 4, 2009 | 10:08 AM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
here you go...
Scroll down to the bottom of the page
http://www.customcorvetteaccessories...lcatchcan.html
Peace
Chip
__________________
..................Click for
Old Aug 4, 2009 | 10:14 AM
Dave68's Avatar
Dave68
Here you go:
http://www.conceptualpolymer.com/PCV...eplacement.htm
Dave
Old Aug 4, 2009 | 10:31 AM
intoc6s's Avatar
intoc6s
Originally Posted by robsc501
Hi onevettenut:
Have a good day
robsc501
O'fallon, il is where they just opened up a Gold s Gym and my (ex) roommate was a Manager there. Really close to the Missouri river/Missouri/St Louis. I lived in that area until about a yr ago.
Old Aug 4, 2009 | 01:03 PM
VinnyT's Avatar
VinnyT
Make sure you check the hose where it connects on the back of the drivers side valve cover. When I bought mine, the rubber elbow part was toast. It was soft as taffy and had collapsed.
Just an FYI...
Old Aug 4, 2009 | 09:30 PM
onevettenut
robsc501 I live in the North end of IL not to far from Dixon
Old Aug 4, 2009 | 09:35 PM
onevettenut
Dave68
The link was just what I needed. Checked it out and will replace pcv this week end.
Old Aug 5, 2009 | 01:32 AM
Dave68's Avatar
Dave68
Glad I could help!
Dave
To Pcv
